Intake sucking oil
Ive got an 88 comanche i just h.o swapped. The small vent line in the back of the valve cover that connects to the intake is being used to consume oil. The intake pulls the oil from the valve train. The valve cover seems fine even did cruisers mod to it but it still sucks oil. Any ideas?
Is that tube clear or partially clogged? Is it shoved down through the grommet too far? $8 will get you a new tube with grommet.
Vac harness 7151365
The tube from the rear of the valve cover to the intake manifold is part number BK 715-1365 or Dorman 46005 and comes with the valve cover grommet.
