battery drainage
My truck had an inappropriatly wired starter relay done by the P.O. where the relay was receiving constant power through the underhood lamp wire instead of the signal wire from the ignition switch. So yes, start with a draw test to at least find from what circuit the draw is coming from. EricTheCarGuy has a great how-to video on this on Youtube, as well as Matt from BleepinJeep as well, IIRC.
