Ben-88Comanche Posted October 21, 2007 Share Posted October 21, 2007 Hey I got in a front end axident a little while ago, and just finished fixing the body/4x4. I put a new vacuum bottle and lines on my truck, as well as the front axle shift motor (off of a 89 pioneer). At the same time i drained the differential and refilled it. The 4x4 still won't work, and when i shift into 4x4 high, it seems to even lose the rear limited slip, and i get stuck even easier. I'm thinking i must have not lined the shift motor up right, so the fork isnt going into the groove, either that or i didnt lubricate the gears inside with grease. If anyone has any idea whats wrong, please help me :cheers: Thanks Link to comment Share on other sites More sharing options...
Oizarod115 Posted October 22, 2007 Share Posted October 22, 2007 is the part-time light on the dash coming on when you shift into 4x? Link to comment Share on other sites More sharing options...
Ben-88Comanche Posted October 22, 2007 Author Share Posted October 22, 2007 yes, the light comes on, the truck thinks its in 4x4 Link to comment Share on other sites More sharing options...
Pete M Posted October 22, 2007 Share Posted October 22, 2007 You could just shift the collar over in a semi-permanent fashion and never worry about it again. There are a few methods for this, including washers, a hose clamp or flipping the hosing upside down. Link to comment Share on other sites More sharing options...
Ben-88Comanche Posted October 22, 2007 Author Share Posted October 22, 2007 Would that mean i can't go into 2wheel drive? <=/ Link to comment Share on other sites More sharing options...
Pete M Posted October 22, 2007 Share Posted October 22, 2007 Your t-case is what shifts you into 2 or 4wd. The Central Axle Disconnect (CAD) in the front axle was Jeep's futile attempt to gain extra mileage by reducing the spinning parts while driving in 2wd (mostly your front driveshaft). But there weren't any tangible gains and so they abandoned it for the reliable non-CAD axles. Another option is swapping in the solid shafts from a later model Jeep and get the bigger 297 U-joints too. U-joint upgrade page Link to comment Share on other sites More sharing options...
clarence Posted October 25, 2007 Share Posted October 25, 2007 You could just shift the collar over in a semi-permanent fashion and never worry about it again. There are a few methods for this, including washers, a hose clamp or flipping the hosing upside down. Can you just simply swap the axles from the late modle axles into the cad axles and eliminate the cad all together? Do you have to change out the spindles to? are the cad housings as strong as the late model housings? Link to comment Share on other sites More sharing options...
JOMJ87 Posted October 25, 2007 Share Posted October 25, 2007 Yes the axles swap. The link goes into it all. With the strength I am not sure but i would think (yes thinking not knowing) That the CAD might be a little stronger because its kinda renforced per say with the sleeved area for the CAD but I'm not sure. That may be crappy steel. I would look into that swap or maybe even makeing a cable connection. I am homebrewing one right now to be installed when i throw my locker in but its not done. I can explain it and take some pics if you are looking to go that route. Cole Link to comment Share on other sites More sharing options...
LEAD_NOT_FOLLOW Posted October 25, 2007 Share Posted October 25, 2007 Just modify the CAD. It's a 15 min job tops. http://comancheclub.com/forums/viewtopi ... c&start=75 (about 1/2 way down) Yes, the older Renix axle's are stronger once you swap out the axleshafts. They have the reinforcement on the drivers side due to the CAD. Link to comment Share on other sites More sharing options...
GirsMJ86 Posted October 25, 2007 Share Posted October 25, 2007 Here is how I did mine, with lots of pics along the way and a short video of it up on stands to make sure it worked, before the front tires just didn't spin. Down towards the bottom. Dial-up warning on that page. http://www.comancheclub.com/forums/view ... c&start=30 Alex Link to comment Share on other sites More sharing options...
