cherokee Posted October 17, 2007 Share Posted October 17, 2007 It looks like it's just a little roll pin, but I haven't managed to get one out yet to replace it. Anyone else replaced any? Link to comment Share on other sites More sharing options...
JOMJ87 Posted October 17, 2007 Share Posted October 17, 2007 I did and yes its a roll pin. I found some at lowes or a carquest shop. Any hardware place should carry the right size. Cole Link to comment Share on other sites More sharing options...
mjeff87 Posted October 17, 2007 Share Posted October 17, 2007 I snagged a bunch of them a few months ago from the junkyard for some guys on here that needed them. If you can't get any, give me your mailing address and I'll send you a couple..... Jeff Link to comment Share on other sites More sharing options...
Eagle Posted October 18, 2007 Share Posted October 18, 2007 How do you get the old ones out? I have a rear door on an XJ that has a busted hinge pin I'd like to replace. Do you just insert a 1/4" punch and flail away with a 3-pound Ford carburetor adjusting tool? Link to comment Share on other sites More sharing options...
DirtyComanche Posted October 18, 2007 Share Posted October 18, 2007 How do you get the old ones out? I have a rear door on an XJ that has a busted hinge pin I'd like to replace. Do you just insert a 1/4" punch and flail away with a 3-pound Ford carburetor adjusting tool? Pretty much. Link to comment Share on other sites More sharing options...
cherokee Posted October 18, 2007 Author Share Posted October 18, 2007 So there's no reason to worry about breaking the actual hinge off? Link to comment Share on other sites More sharing options...
Oizarod115 Posted October 18, 2007 Share Posted October 18, 2007 So there's no reason to worry about breaking the actual hinge off? long as you've got a welder there's no reason to worry... :roll: Link to comment Share on other sites More sharing options...
jeepthing07 Posted October 18, 2007 Share Posted October 18, 2007 you can stick 1/4" bolts (ones with a long sholder and cut off the threads) in place of the pins they fit perfect. its what i used when i did my removeable door's Link to comment Share on other sites More sharing options...
mjeff87 Posted October 18, 2007 Share Posted October 18, 2007 How do you get the old ones out? I have a rear door on an XJ that has a busted hinge pin I'd like to replace. Do you just insert a 1/4" punch and flail away with a 3-pound Ford carburetor adjusting tool? Slip-joint pliers. The head has the perfect offset to push the bottom of the pin up. Once it pops out of the hinge, rock it side to side while pulling up and it'll come right out. Jeff Link to comment Share on other sites More sharing options...
JOMJ87 Posted October 18, 2007 Share Posted October 18, 2007 Mine were rusted BAD but only one had to be drilled out with a 1/4 drill bit. Others just took a few licks with the ole BFH. My 3 lb sledge was great for it and i didnt break my hinges off. Cole Link to comment Share on other sites More sharing options...
