coheed Posted July 6, 2020 Posted July 6, 2020 2.8/ Column shift A904/ didn't check/ D30/ D35/ LWB Build date: N/A Current Location: Rusty's pic-a-part in Marion, NC Status: Junkyard Notes: Nothing special of note. Current owner: Rusty's pic-a-part Most everything MJ specific is gone. I nabbed the window trim and the fuel door off it today. It does have a decent condition factory slider window, but I didn't have my glass tool in my toolbox . @Blaine.D this one is not too far from you if you want a factory slider, or maybe someone can pay you to get it.
eaglescout526 Posted July 6, 2020 Posted July 6, 2020 *ZZ TRIM STYLE ZZ - PLASTIC BUCKET SEAT -ZZ ADA LIGHT PACKAGE ADB PROTECTION GROUP PACKAGE AJZ AWH POWER EQUIPMENT GROUP AWJ Visibility Group BAC 75 AMP ALTERNATOR BCQ Battery - 750 Amp Maintenance Free CGX Head Restraints-Outboard Seating, RR CKA CARPETS - CLASS I SHORT PILE 8 - 12 OZ DGZ Transmission- 4-Spd. Automatic,MT643 EFB ENGINE - 2.8L GM 6CYL GAC ALL WINDOWS - TINTED GLASS GFD SLIDING RR WINDOW GTZ MIRRORS - MANUAL REMOTE HAA AIR CONDITIONING - FRONT HCC HEATER W/UPR LEVEL VENTIL - TYPE II JAY Instrument Cluster w/Tach JGB Clock - Digital JHA WINDSHIELD WIPERS - DELUXE JJA CIGAR LIGHTER - FRT COMP K60 BODY SIDE MLDGS - VINYL LBB COURTESY LAMPS (BELOW PANEL) LMA HALOGEN HEADLAMPS LPE EXTERIOR CARGO LIGHT MBJ Bumper - Front, Black MCA FRONT BUMPER GUARDS MCB REAR BUMPER GUARDS MDA FRT LICENSE PLATE ATTACH REQUIRED MFD BRIGHT GRILLE - TYPE I NAA ESA W/CATALYST (EXC CALIF SYSTEM) NFA TANK - 20 GAL FUEL NHM AUTO SPEED CONTROL NMB ENGINE COOLING - STANDARD DUTY RAF RADIO - AM/FM/MTR SBA POWER STEERING SCE STRG WHL - EURO/SPORT TYPE SUA TILT STEERING COLUMN WJM Wheels - 15 x 7.0 Chrome Build date 9/2/85 Body code TP62
Pete M Posted July 6, 2020 Posted July 6, 2020 33 minutes ago, coheed said: Most everything MJ specific is gone. how's the bed? any rust?
coheed Posted July 6, 2020 Author Posted July 6, 2020 6 minutes ago, Pete M said: how's the bed? any rust? It was fairly straight aside from the bottom back corners. Don't recall a whole lot of rust, but it was filled to the brim with crap so I couldn't see the floor of it.
Blaine.D Posted July 8, 2020 Posted July 8, 2020 On 7/6/2020 at 4:06 PM, coheed said: 2.8/ Column shift A904/ didn't check/ D30/ D35/ LWB Build date: N/A Current Location: Rusty's pic-a-part in Marion, NC Status: Junkyard Notes: Nothing special of note. Current owner: Rusty's pic-a-part Most everything MJ specific is gone. I nabbed the window trim and the fuel door off it today. It does have a decent condition factory slider window, but I didn't have my glass tool in my toolbox . @Blaine.D this one is not too far from you if you want a factory slider, or maybe someone can pay you to get it. Thanks for the tip. 👍🏼 By chance did you see any Cherokee that still have passenger side axle shafts?
coheed Posted July 8, 2020 Author Posted July 8, 2020 2 hours ago, Blaine.D said: Thanks for the tip. 👍🏼 By chance did you see any Cherokee that still have passenger side axle shafts? I know there were 4-5 Cherokees, both body styles. At least 2 were 4wd, not sure on axles shafts. They had 4-5 ZJ's as well.
