Raven Posted June 18, 2020 Share Posted June 18, 2020 For those that have done, are in the process of, or have plans on paper... I want to keep the original parking brake location. I am keeping my factory bench seat. Everything else is being converted at the moment. Please post pics of your setup. Thanks 😁 Link to comment Share on other sites More sharing options...
Dzimm Posted June 19, 2020 Share Posted June 19, 2020 It won't work in the factory XJ position with the bench seat as the handle position is way too far back. Also you will have to build yourself a passthrough either by welding in the XJ parts, or build a bracket to support the XJ parts above the floor, and run the cable through the original MJ cable grommet. I chose the later option on my red truck, I used the 96- handbrake but the concept is the same, just a little different mounting. I actually used the MJ parking brake cable attachment point for mine rather than the XJ parts as I didn't have them. It fits between the bench and console ok but at full pull, it contacts the console. Would work well with a shorter handle, which you may have to do in your case because it barely clears the older dash, I'm almost positive it wouldn't clear the 97+ dash. Link to comment Share on other sites More sharing options...
Raven Posted June 19, 2020 Author Share Posted June 19, 2020 Dzimm... that’s a cool setup. I actually cut out the floor where the XJ hand brake is. I didn’t think it would fit by the shifters with the bench seat. I want to stay with a bench seat. I also want to stay with the parking foot brake on the floor in the factory position for the MJ. It’s not as practical as a hand brake for controlling decent or holding a hill. Link to comment Share on other sites More sharing options...
75sv1 Posted June 19, 2020 Share Posted June 19, 2020 For some reason I was looking at doing this. I think I was looking at a ZJ e-brake setup. Link to comment Share on other sites More sharing options...
Dzimm Posted June 21, 2020 Share Posted June 21, 2020 I must have read your post wrong. Rereading it sounds like you are doing a 97+ conversion on your truck but want to keep the pedal brake? In that case I don't think it's possible to keep it as the steering column brace/ dash mount goes right there. I'll go take a peak at my 97+ truck to see what kind of room you have there when fully assembled. Link to comment Share on other sites More sharing options...
gogmorgo Posted June 23, 2020 Share Posted June 23, 2020 On 6/19/2020 at 1:39 PM, 75sv1 said: For some reason I was looking at doing this. I think I was looking at a ZJ e-brake setup. Cause I had easy access, here’s some comparison shots. These came out of a ‘92 XJ and ‘93 ZJ. The ZJ lever is the same length as the XJ, just a little chunkier. Pretty well the same size, the two look like they would even bolt in each other’s place. The big difference is the ZJ handle attaches to a cable that runs under and through to the equalizer bar, instead of being riveted to a rod that pulls on it directly. I imagine that would give it a more flexible mounting position to be reused in another vehicle. Link to comment Share on other sites More sharing options...
