I have an 87 Comanche that worked fine up until last week. I parked it and the next day it wouldn't start. I turn the key and nothing happens. The battery is charged and the starter works when tested. I replaced the ignition relay and the ignition switch but it still won't start. Any help would be appreciated.
Welcome to the CC forum.
LOG-IN. Upper right hand of screen. Click on Username. Click on Account Settings. Find and click on Signature. Add vehicle information here (YR, ENG, TRANS, etc, etc) and save. This helps everyone. This information will be available every time you post.
do you have a multimeter?
Does the starter relay click when you turn the key to START? Turn on the headlights -- when you turn the key to START, do the lights dim at all or do they stay bright?
