i know this topic has been asked a million times, but I am going to ask it again (for the fact it is 2020, and there must be some more options available to what is found in the search)
looking for recomendations on a 3 link kit. i have 2.5" lift built into the axle and 7.5" lift coils, on paper 10" but about 8.5 with the coil sag and extra metal on the front.
what would the community reccomend? the truck has been running modified short arms robert bryce built in the early 90's and with the 40' tires the unibody is finally to not play anymore (i have a complete frame stiffener kit waiting to go on as well so integretity is not an issue)
thanks in advanced
Stinkyfab or ironman4x4 are you're best bet IMHO. IRO makes a decent kit for the money. I have a cavfab on the MJ but was on there from before and I haven't wheeled on it. Sucks it's only the 1 piece cross member and  the upper bolt interferes with the gas lines. Dirtbound, core few others have kits too.
If you're up to it you could fab up something especially if you link the rear.
I have the IRO 3 link and it works great on the MJ.  It's a pretty easy install too.  The only thing to be aware of is the MJ's brake and fuel lines.  They route different than on my XJ, so you have to pull them out a little from their plastic retainer near the crossmember.
