Bobby anderton Posted May 12, 2020 Share Posted May 12, 2020 Does anyone know the lengths and pitches of bolts for the AX15 bellhousing going into 4.0 wanting to upgrade to grade 8 and get rid of the e12 head. Link to comment Share on other sites More sharing options...
87MJTIM Posted May 12, 2020 Share Posted May 12, 2020 A parts manual shows the bolts are: The side bolts (9 O'clock and 3 O'clock) are 7/16" x 14 x 3 1/8" The top bolts are 3/8" x 16 x 1 7/8" Link to comment Share on other sites More sharing options...
Pete M Posted May 12, 2020 Share Posted May 12, 2020 my suggestion is to use studs for the top 2 bolts. they help as guides for re-installation of the transmission Link to comment Share on other sites More sharing options...
JMO413 Posted May 13, 2020 Share Posted May 13, 2020 Studs are much easier for sure. Link to comment Share on other sites More sharing options...
BeatCJ Posted May 18, 2020 Share Posted May 18, 2020 Since I intend to do the same thing, do you use the same length studs, or add 3/8" or so for nuts? Link to comment Share on other sites More sharing options...
Pete M Posted May 18, 2020 Share Posted May 18, 2020 they can be a bit longer than the exact length of the old bolts. but I did that like 15 years ago so I'm not sure of the length I used. let's say the originals were 2", then add a half inch for the head and then another half inch for some slop (the studs go into the block a bit further than the bolts would have) Link to comment Share on other sites More sharing options...
BeatCJ Posted May 19, 2020 Share Posted May 19, 2020 Perfect, that's kind of what I thought. When I installed a ZF-5 in my '87 F-350, I built some tapered guide bolts for the 2 lowest holes. Got all the other bolts started, and swapped the right bolts in. Of course, a ZF-5 is quite a bit heavier. Even heavier than the iron cased T-19 I replaced. Link to comment Share on other sites More sharing options...
