1988 Jeep Comanche Rear Suspension Prts
Does anyone know where I can purchase the following parts for a 1988 Jeep Comanche Pioneer, 4.0l, 4wd? I am unable to locate any of them.  Thank you in advance.
Jounce Bumper 52002078
U-bolt 52002885
Shock Mount Plate 52001832
-Brian
The u bolts are dependent on what axle you have, assuming you have a Dana35 so look for ubolts for a Dana35 and you'll find what you are looking for.
The shock mount plate is not available new, I'm sure there is a company that makes plates that would work but after 10 posts you will get access to the classifieds here and can get a set of factory plates from a member.
Side note, I got lucky while doing my Dana 44 swap... I was in a pinch because I forgot to order u-bolts; turns out the u-bolts from my 1998 Ranger 2wd (with a Ford 7.5 diff) are exactly the same! ;)
