90-96 footwell light connector
I’m trying to install some 90-96 footwell lights in my 86 and I can’t figure out what crimps I need for the female end. I have both male and female connectors but no source for the female crimps and id really like to avoid splicing them. Anyone know what crimps I need?
The picture with the yellow arrow is female connector.
These are the lights I have:
The '91 and up (this is an early example of this starting) wiring harnesses are littered with Chrysler proprietary connectors that have absolutely no information available for them. That looks like another one of them. I haven't been able to find the bare contacts for any of the ones I've looked for. Are there any markings molded into the plastic of the connector?
They do have markings on the connector, I’ll have to report back once I’m home from work and I’ll also snap a picture of the crimp itself. I’ve seen a few that look similar on clipsandfasteners.com but wanted to confirm before I bought a pack of them. Thanks for the quick response
Unless you are trying to restore your MJ to factory condition, ditch those weird proprietary connectors and go buy something on Amazon.  Given that the application is an interior electrical connector, the need for environmental sealing (waterproofing) is non-existent, so a bunch of stuff is out there for cheap.
Here is a good example of something you can use:
https://www.amazon.com/MUYI-Waterproof-Connector-1-5mm-Terminal/dp/B01A6LTK44/ref=psdc_15729341_t1_B01F54PFLE
Agreed.
If I were in your place, I'd go with some unsealed Metripack 150 connectors. That connector line was heavily used in Jeeps anyway so it would look proper, generic crimp tools work just fine for the contacts, and they can be had by the boatload cheaply as components on Mouser. Just make sure to pick the connector so that you can't accidentally plug something in incorrectly. AMP has a few lines of connectors that are good for this purpose as well, and I especially like them for audio installs.
Just now, Minuit said:
Agreed.
If I were in your place, I'd go with some unsealed Metripack 150 connectors. That connector line was heavily used in Jeeps anyway so it would look proper, generic crimp tools work just fine for the contacts, and they can be had by the boatload cheaply on Mouser. Just make sure to pick the connector so that you can't accidentally plug something in incorrectly.
That's a good alternative, if you actually have crimp tools.  If you don't (like me), I just solder/heatshrink the connector pigtails into the wiring.
The old Molex "Econo-Latch" connector is PERFECT for this role for interior lighting connectors, as it's cheap and simple, as well as being polarized.   Too bad it requires a lugging tool to attach the contacts to the wires correctly.
Yep, love those too. If memory serves, the 0.062" version is the connector used by the S10 blazer dome lights that a lot of people use to replace the originals. I have a sneaking suspicion that the Renix diagnostic port is a variation on that connector too.
Thanks @Minuit and @AZJeff I had no idea these were such an obscure connector. Id like to avoid soldering or splicing the wires together so I’ll probably just go with a buildable connector as I have some basic crimp tools. Not looking for a factory restoration but I don’t want it to look as out of place as my head unit lol.
Thanks again for the suggestions
To answer the original question -- they don't exist (female side). I've looked high and low. But, if you were working on the male side of the terminal there is a Ford terminal that is an exact fit to those. It's in a small 8 pin set at O'Reilly's Auto. It comes in a mix of Ford and Chryco terminals male/ female. The matching female terminal in this kit is nothing like what you need unfortunately.
Thanks for info, I’ll probaly just end up getting a new male and female connector and pinning that. It’s just my luck that I get such an uncommon set of connectors.
Blame Chrysler. Minuit and I spent about a day doing PM's on finding out who supplies Chrysler with their terminals and kits. I couldn't even find anything in the electrical connecter catalog.
I appreciate the persistence, I’m becoming less and less surprised with some of the bone head things Chrysler/AMC do. It’s like the engineers get there kicks from making things complicated.
Given that the AMC-era connectors were such a piss-power excuse for completing electrical circuits, I would go out of my way to replace that junk with something better (unless you are attempting a "pure" restoration of your MJ/XJ.)
I cannot beleive the connectors that were chosen, even in the period when the MJ/XJ was designed (the mid-1980's).   There were SO MANY better connectors that had been in use for MANY years by other auto makers at that point.   It's almost like the AMC electrical design team tried to surpass British Leyland in choosing the most worthless interconnect systems for the elecrtrical wiring.
Mouser and the Delphi catalog (you can just plug the part numbers from the catalog into Mouser) is my usual source, but I buy these in bulk (often tens or hundreds of contacts at a time), your mileage may vary :dunno:
Do they come as a kit with the connectors, crimps, and locks from mouser?
No. Just gotta look the part numbers up. A lot cheaper than ordering "kits" though - that's all they did to assemble the kit I'm sure.
