Reverse Light switch
87 comanche, 4.0, 5spd
My reverse lights were not working when i bought the truck. After checking under i realized the cables coming out of the reverse light switch were broken. So i got a replacement. However I can not find a male connecter for my switch. I'm lost.
8 minutes ago, jdog said:
Right side of the engine should be near the firewall and heater hoses, there will be a plug
But the wire is like 4 inches before it gets to the female connecter how am i suppose to reach over there?
When I got my truck someone had replaced the connector which probably melted from the trans or exhaust heat and used some spade connectors in the factory connectors place I haven't an idea why it was done. But like jdog is saying theres a four pin connector on the passenger side of the engine bay right by the fire wall and engine. Should be the only wiring harness going to the trans aside from whatever 4 wheel drive harness there is.
Is it this one?? its on the passenger side and near the firewall, I'm unsure what the one next to it is but its on the same "harness".
Sorry guys but i just can't figure it out. I went to a local junk yard and got the connector and wires i needed, i wired the connecter on the switch and tried connecting it to both of these and no luck, any ideas?
Get a test light. Put a fuse in.
With KOEO, put the trans into reverse.  Test the power into the reverse switch, C111, BLK w/ Yel.  Test power out of reverse switch, C111, BRW, w/WHT.
If no power out of the switch, then replace switch.
If both of these are good, move to the rear.
Test wire at rear harness C159, BRW w/ WHT.  If power getting to the rear, then test the sockets.
If any of these do not light the test light search for breaks before the fail point.  Between C111 and C159, there are several connectors (C104, 157, 158) that all have BRW w/ WHT wires. Wire breaks or corrosion could disrupt the power.
16 hours ago, 87MJ_ said:
Added the fuse, and no luck, I'm running out of ideas 😂😂, anybody got any suggestions.
with the fuse added, did you connect it to the 4 wire connector?
