WanderingAccountant Posted April 10, 2020 Share Posted April 10, 2020 Hi all, I was attempting to diagnose a high idle upon ignition, and discovered that a silver hose connected to the base of my air filter hub had broken in place. I should probably replace, but I can’t figure out what this hose is called, or what better part to replace with. The other end seemingly snakes under the engine and looks very tricky to access! Please help! Link to comment Share on other sites More sharing options...
eaglescout526 Posted April 10, 2020 Share Posted April 10, 2020 It is an exhaust hose. There is a vac switch right at the intake of the air box that shuts a door and allows the exhaust to send warm air into the intake rather than draw from the freezing cold air upon initial startup and warming of the engine. Link to comment Share on other sites More sharing options...
tugboat95 Posted April 10, 2020 Share Posted April 10, 2020 Lol. I just replaced mine today. Yours is not factory. Somebody found a duct and put it in. It is a ignition pre heater hose I think. What it does is sends hot air to the airbox to help starting. It is attached to a vacuum switch that operates as needed. At least that's what was explained to me. Look at my photo. I just pulled this one off a junker today and replaced my worn out hose tonight 89 Comanche Eliminator 2wd 4.0L 5 speed PukeGoat Factory Original Link to comment Share on other sites More sharing options...
eaglescout526 Posted April 10, 2020 Share Posted April 10, 2020 3 minutes ago, tugboat95 said: Somebody found a duct and put it in I don't know, kinda like it. Looks cleaner and less likely to tear and its readily available. Link to comment Share on other sites More sharing options...
WanderingAccountant Posted April 10, 2020 Author Share Posted April 10, 2020 Awesome fellas, thank you! Anyone know a good replacement part for this? The only one I could track down is the same flimsy metal coil, and I would rather have something more durable! Thanks you both for your responses. Link to comment Share on other sites More sharing options...
Ωhm Posted April 10, 2020 Share Posted April 10, 2020 On 3/24/2020 at 12:00 AM, Big Dan said: I bought a hose from McMaster-Carr. I think it was 2.5in ID. One of their blue crush resistant duct hoses. Quote from another posting. Link to comment Share on other sites More sharing options...
tugboat95 Posted April 10, 2020 Share Posted April 10, 2020 I got lucky and pulled it off a junkyard. Still in great shape I looked at all the local auto parts stores and couldn't find the proper size. I hadn't searched Grainger or McMaster type places yet. But when I was going to get serious about it they were my next places to search.89 ComancheEliminator2wd4.0L5 speed PukeGoatFactory Original Link to comment Share on other sites More sharing options...
Ωhm Posted April 10, 2020 Share Posted April 10, 2020 @tugboat95 yeah you got lucky. Even came with that protective wrap for the rubbing point. Link to comment Share on other sites More sharing options...
WanderingAccountant Posted April 10, 2020 Author Share Posted April 10, 2020 @tugboat95 that is seriously perfect! That was my problem; where the power steering system sits rubbed a hole into the cheap hose. @Ωhm that is awesome!! I measured the fitting and it seems like the 2in would fit better? Do you agree or am I not considering something? Link to comment Share on other sites More sharing options...
Ωhm Posted April 10, 2020 Share Posted April 10, 2020 I'd take measurement at the air box. Should/will be the same diameter used on the medal shroud over the exhaust manifold. Link to comment Share on other sites More sharing options...
WanderingAccountant Posted April 10, 2020 Author Share Posted April 10, 2020 Very good, ordered some today! Thanks everyone! Link to comment Share on other sites More sharing options...
Ωhm Posted April 10, 2020 Share Posted April 10, 2020 One more thing. O.D. of air box is I.D. of hose. Link to comment Share on other sites More sharing options...
rmb2485 Posted April 15, 2020 Share Posted April 15, 2020 Just to clarify, that doesn’t actually send exhaust gas to the intake, it sends warm air from around the exhaust manifold to the intake. It just connects to a flange on the outside of the exhaust manifold.Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
