30s fit with no concerns whatsoever.  :L:  31s with the good possibility of rubbing at full lock (can be fixed with the WJ arms)
stock rims are required for 31s or you will be rubbing those 31s on the flares.  probably pretty bad depending on the backspacing.
  • 3 weeks later...
On 4/1/2020 at 7:33 AM, 88towmanche said:
31's on factory rims  - does have about 1-3/4 budget boost but wasn't necessary for clearance.
WJ LCA's were necessary
That's a nice looking truck!!
