LT1 and 4L60E
Ok so who has a good write up and advice reference putting a LT1 and 4L60E out of a 95 Formula into a 88 Comanche 4x4? Already have the motor and tranny!!!!! The harness will be done this week. Anyone know of the total price of the Novak kit or another kit? What would be the best headers / manifolds to use?
Thanks
I will post pics as I can.
The LT1 has a lot of unique things associated with it and it's kind of the redheaded step-child of the Chevy small blocks.  Few people want to bother with them.  I seriously doubt there are any writeups anywhere, unfortunately.  The only advice I can offer is to keep absolutely everything from the donor that you can and install it all together.
The LT1 block is a slightly tweaked Gen 1 350.  Most of the changes are on the front and with the intake.  The mounts should be standard SBC so the Novak kit would put the block in the right place.  The transmission will be standard 4L60 so the trans mount will be like everyone else.  Engine accessory locations may be an issue.  And finding relocation brackets, if needed, may be "challenging".  Running the dash may require some creative engineering or just punting and wiring up extra sensors, leaving the ones for the computer alone.
Best of luck to you.
This has basically started from the BA-10 going out and the renix 4.0 having had seen its better days. So this is now taking place to hopefully add to the mighty Comanche being more reliable. I did go with the 95 Formula LT1 and 4L60E because it was all there and Ive read some stuff about trying to use the car V-8s as they are not as tall vs the trucks. Just saving some time on switching out the upper I guess.
The tall intake issue is with the LS truck blocks 1999 and newer. The 4.8, 5.3, and 6.0 from the early 2000's at least have a very tall intake that hits the hood.  The LS1/LS6 intake manifold from the cars is quite a bit shorter and bolts right up.  And it fits better under the hood of an XJ.
The LT1 has a slightly taller intake manifold and may suffer the same problems as the truck style LS intakes.  But I can't say for sure.
The only way to use an LT1 is to get a full running/driving donor with an intact wiring harness and computer.  Take absolutely everything for it at once.  Don't cut a thing.  You won't be able to find many replacements for things like that.  And there isn't much aftermarket that supplies alternatives.  Like I say, the LT1(and LT4) are the red-headed step children.  They were only produced for 6 years and they are full of unique parts.  The block, the heads, the OptiSpark distributor in front of the engine, all of it.  It's weird.  It's unique.  And not many people like it.  It works fine if you're set on using one.  Just know the aftermarket is worse for these engines than it is for the MJ.  But a unique, limited run engine in a unique, limited run truck would be appropriate.
Look at Novak for the conversion kit for the 4L60 so you can run a transfer case.  It will put a speed sensor on the transmission tail shaft so that the computer can shift things correctly no matter if you're in high range or low range.  In fact, you don't connect any transfer case wires to the donor computer.  You can keep the speedo cable in your transfer case to run your dash.  For dash gauges, you're better off adding factory sending units for oil pressure and water temp somewhere you can find room.  Some conversion radiators (hoses switch sides so you need a new radiator) have a port for a temp sender.  You can put a "T" fitting on the oil pressure tap in the block and run 2 senders.  Keep the one that goes with the engine for its computer and take the one out of your Renix engine and connect it to your factory wiring harness.
Other than that, it should be pretty straightfoward.  As unique as the LT1 is, it's still just a modified first gen small block chevy.  Once you get outside the block and heads, it looks like many other small block chevy engines.
Well looks like I may have screwed up on the engine not doing my homework thoroughly like I thought I did. But with that being said I am getting everything from the donor car... computer flashed, harness made from a specialist etc etc.... and the tech support on the back end as the seller of the engine is an F body specialist and has / is familiar with repurposing engines.
I have driven many L-98 & LT-1 cars and have been happy with its performance and think that it would compliment the comanche well. Much the same as any 5.3 might. The LT1 IMO has more of a power band  / torquey motor than any 5.3 Ive ever driven.
Any suggestions or ideas on what manifolds might work the best?
FYI I'm not doing this myself but am assisting the guy with "ideas" on whats been done and what may work.
It's a decent engine, and will work well in a Comanche.  It's just not used often and lacks aftermarket support.
Since you have a specialist that knows these engines and has experience swapping them, a lot of the potential problems will be mitigated and make this an easier swap that trying to tackle it yourself.
Exhaust manifolds should be block huggers.
I'd recommend starting here for basic information:  http://www.novak-adapt.com/knowledge/engines/swap-guides/chevy-buick-gm/xj-swap/
That's a good starting point for general swap information and advice for a GM engine into an XJ/MJ.
Oh, and please take pictures and post details as the swap progresses.
I'm still tossing around lots of ideas for my own engine swap.  I'd like to do something more in the unique side myself and have been looking at several options.  If this goes well, I may put the LT1 back on my list. :)
Soooo the engine and tired BA-10 are out.
FYI The engine still ran good if anyone is in the market for an 88 4.0 with under 130k.
#1 Ran into an issue with the fuse box..... what fuse boxes are compatible as this one is basically shot from since before the days that the clutch master cylinder was replaced.
#2 any ideas on what pedal assemblies can be used vs just cutting off the clutch pedal?
next up test fit with the Novak engine and tranny mounts.
Thanks  In advance
Thanks  In advance
any auto XJ should be able to provide you with a 2 pedal setup  and older auto XJs can be used as fusebox donors :L:
FYI: Novak's adapter kit for the 4l60e to NP231 modifies the transmission.  Advanced Adapter's kit modifies the transfer case.  The t-case is WAY easier to work on, so that'd be my recommendation on that piee.  Otherwise, it looks like Derf has you covered.  The guys at Novak were very helpful when I called them up (it's not always easy to get a hold of them, but when you do, they have a lot of pretty good expertise).
For the 700R4/4L60 (up to 92) and early 4L60E (93-96), the Advance Adapters kit only comes with a transmission tailshaft.  Only the '97+ adapter comes with an option for a different input shaft for the t-case.
And converting the 2WD donor transmission will require a tailshaft swap no matter what so it's a bit of a moot point.  You may as well do the kit with the new tailshaft.
Score at the parts yard today. This beauty is out of a clean 92 XJ. There was also a 95 that had a nice one as well. Never realized how bad mine really was until after seeing the salvaged one.
Another victim to a clutch master cylinder.
Like Pete says check it before it’s too late!!
Just a little bit of research an this makes sense...
Lower Power Steering Shaft for 84-94 Jeep Cherokee XJ and 86-92 Comanche MJ
Finding  these two XJs is sure coming in handy.
Might just get me an XJ. LOL
  • 3 weeks later...
Ok so we got the engine harness back from the shop. Fuse block from the yard, Tranny and NP 231 are getting the good once over at Erie DriveTrain, Inc. (814) 833-8866, FYI Scott does exceptional and reasonable work.  front and rear gears,,,,,,,,3:73s . Engine mounts. Headers in from Novak along with tranny mounts and 23 spline and LT1 4L60E adaptor kits. etc etc its been a bigger deal so far. Going back to to the yard where there are 2 beautiful 92 and 95 XJs with tons of nice parts, Going to pull the pedal assembley, battery tray, visor clip and left window regulator. If you need parts hit up Tony at Bizarro's Erie Auto Salvage and Towing 455-5741..... tell him what you need and some clean jeeps will appear.
I also have a good running 4.0 110k ish that we just pulled out of the beast to trade out with the LT1. Really nothing wrong with this motor at all, lots of life yet. telling ya. if it wasn't for tor the BA-10 going itd still be in there, kinda regretting it unitl we get the lT1 in there up and running.
I do not. But I have also contemplated, a 2nd build whether to go LSx/T56 low/street Comanche, or prerunner.
anyone got a nice 2WD?   might just drop a LS in it and lower it this time
hahahaha
