Dreaded fuel pump wiring
  • Replies 79
Looks like you didn't have to travel too far. What a mess.
Agreed. Now to figure out what all goes where. And try to put it back together. I think the issue is the red wire that runs that loom back to the pass side isn’t getting power and red is usually pos
Update. Pulled all relays(5) from engine bay. Bench tested for activation as well as OHMs. All tested between 74-78.5 ohms. Cleaned relay connections and wires. Pulled the looms back on driver side, from the relay harnesses that goes to the firewall to the fuse block and the one that goes to the oxygen sensor heat relay. I checked and cleaned the wire for the Ballast on the starter relay. Cleaned up and made new connections where had been spliced previous. Couple spliced wires that make no sense. E fan is pulling power from grey plug attached to EGR connector. But only comes on when key is on, AND with the hot wire from Fuse block.
So another update. Wired everything back up as previously done. Loomed everything and taped everything. Especially connections with butt connectors. Now when I turn the key over the fuel pump will prime as before, the efan will turn on as before but now my AC clutch engages. Even when pulling the ac clutch relay it still does it. Didn’t do this before.
that four pin weather pak goes to the a/c harness. whichis the a/c relay low pressure switch and a/c compressor
So that would explain why the ac clutch is now clicking. When It never did it before what did I screw up
