Drive Shaft Question?
Rear, unbolt at axle and pull.  It may have some stiction (sticky friction) making it feel stuck.  Pull a little harder.
Front takes multiple steps.  Break loose the 2 bolts that you can get to at the transfer case side.  The head of the bolt is at the yoke coming out of the case and it faces the case.  Once those 2 are out, unbolt the axle side and pull it loose.  Spin the shaft halfway around and reinstall at the axle loosely.  Break the other two bolts loose at the transfer case yoke.  Then just finish removing at both ends and pull the shaft.
Ok so I unbolted it from the rear axle
now I just pull and slide it out of the transfer case, sounds easy
now I have to unbolt the tranny from the front, do I start with the bolts on the flex plate / starting wheel ?
Ok I got the tranny and the transfer case out
the filler neck for the tranny where you check the fluid level really gets in the way, I was wondering if there’s a way to remove it ?
Also how do I find out what transfer case I have ?
