KatahGii Posted March 24, 2020 Share Posted March 24, 2020 Ok so I’ve been trying to figure out why my fuel pump isn’t getting power I tested my fuel pump and it it working. Now I’m moving on to testing each connected to see where the power is dropping. This is the connector under the flooring that goes to under the bed. It’s got 6 wires colored wires. Anyone know where I can find a pin out so I can test the wires to the fuel pump? Link to comment Share on other sites More sharing options...
Ωhm Posted March 24, 2020 Share Posted March 24, 2020 Fuel pump wire is orange. C158_F. Fuel pump voltage will time out (2-3 seconds) with KEY ON. Link to comment Share on other sites More sharing options...
KatahGii Posted March 24, 2020 Author Share Posted March 24, 2020 20 minutes ago, Ωhm said: Fuel pump wire is orange. C158_F. Fuel pump voltage will time out (2-3 seconds) with KEY ON. Ok fuel pump positive is orange. Do you know which is gonna be the negative on that connector? Also where do you get these images I’m probably gonna need more;) Link to comment Share on other sites More sharing options...
Ωhm Posted March 24, 2020 Share Posted March 24, 2020 Ground (G107) is near the left taillight. Link to comment Share on other sites More sharing options...
JMO413 Posted March 24, 2020 Share Posted March 24, 2020 mj1988electricalmanual_(1).pdfpdf Here's a link to the electrical manual. Link to comment Share on other sites More sharing options...
KatahGii Posted March 24, 2020 Author Share Posted March 24, 2020 12 minutes ago, Ωhm said: Ground (G107) is near the left taillight. I have re-done the ground like cruiser said to do. I was just assuming there would a negative terminal on the connector. Link to comment Share on other sites More sharing options...
KatahGii Posted March 24, 2020 Author Share Posted March 24, 2020 47 minutes ago, Ωhm said: Fuel pump wire is orange. C158_F. Fuel pump voltage will time out (2-3 seconds) with KEY ON. I’m sorry I’m just trying to get an idea of the wiring. Under the dash Do you know which one of these connectors Does the fuel pump go through? Link to comment Share on other sites More sharing options...
Ωhm Posted March 24, 2020 Share Posted March 24, 2020 You had to go and find that 1%. Good question. If C119_10 is orange use that. 88 Electrical manual will show C157_F as orange. Fuel pump. C157 should be the correct one. Link to comment Share on other sites More sharing options...
KatahGii Posted March 24, 2020 Author Share Posted March 24, 2020 13 minutes ago, Ωhm said: You had to go and find that 1%. Good question. If C119_10 is orange use that. 88 Electrical manual will show C157_F as orange. Fuel pump. C157 should be the correct one. Thanks. You have been so much help I’ll keep you posted on my progress. Link to comment Share on other sites More sharing options...
ghetdjc320 Posted March 24, 2020 Share Posted March 24, 2020 I use all data diy for my electrical diagrams and connector pinouts Link to comment Share on other sites More sharing options...
