9 hours ago, SatiricalHen said:
They can be repaired, the see I had were real bad, but I redid them.
mine are beyond repair unfortunately. The actual housing has been destroyed
I grabbed some vents from a truck today. Only 96k on the truck
I’m assuming he got one because he stopped replying to the PMs with me.
Actually guys, I got really sick for a while. Still need a set but I can’t even receive them until we are out of quarantine here which is tentatively set for mid April.
  • 4 months later...
@SatiricalHen
Exactly what material did you use to replace the rubber pieces?
What is the best approach for pulling those plastic pieces from the cab?  Does one end/side pop out easier?  Mine don't want to budge, and I don't want to crack them them.
@SatiricalHen
Some rubber sheeting I bought on amazon. I have a bunch left over from that. It’s a little thicker than the factory stuff though. I used a couple screw drivers and carefully popped the side tabs out then go and pop the bottom tabs out and slide down kinda. I’ve popped 3 or 4 sets of them out now. Let me see if I can find the amazon order and find out exactly what I actually ordered.
Thank you for the rubber tip and the removal advice!
I have not re-installed my cab vents yet, but here they are.  I am tempted to glue a little stick across the three tabs to ensure the flaps don't come off like the factory ones did.  The rubber sheets are 1/16" thick or ~1.6 mm thick.  I happened to have one survivor stock flap, and it measured 0.5 mm thick.  I definitely wish this new rubber was a bit thinner.  I used a 3/32" punch to make the holes.
