ghetdjc320 Posted March 13, 2020 Share Posted March 13, 2020 Looking for a pair of cab vents. Just need the actual pop in insert. Mine are beyond repair. Let me know what you have Link to comment Share on other sites More sharing options...
buxmj Posted March 14, 2020 Share Posted March 14, 2020 PM sent Link to comment Share on other sites More sharing options...
SatiricalHen Posted March 14, 2020 Share Posted March 14, 2020 They can be repaired, the see I had were real bad, but I redid them. Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
ghetdjc320 Posted March 15, 2020 Author Share Posted March 15, 2020 9 hours ago, SatiricalHen said: They can be repaired, the see I had were real bad, but I redid them. Sent from my iPhone using Tapatalk mine are beyond repair unfortunately. The actual housing has been destroyed Link to comment Share on other sites More sharing options...
SatiricalHen Posted March 16, 2020 Share Posted March 16, 2020 mine are beyond repair unfortunately. The actual housing has been destroyed Ah alright Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
SatiricalHen Posted March 16, 2020 Share Posted March 16, 2020 I came across some cab vents today in pretty good condition if you still need them. Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
Goose_XJ88 Posted March 22, 2020 Share Posted March 22, 2020 I grabbed some vents from a truck today. Only 96k on the truck Link to comment Share on other sites More sharing options...
SatiricalHen Posted March 22, 2020 Share Posted March 22, 2020 I grabbed some vents from a truck today. Only 96k on the truck I’m assuming he got one because he stopped replying to the PMs with me. Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
buxmj Posted March 23, 2020 Share Posted March 23, 2020 I assumed he got them because he stopped replying to our PM conversation. Link to comment Share on other sites More sharing options...
ghetdjc320 Posted March 29, 2020 Author Share Posted March 29, 2020 Actually guys, I got really sick for a while. Still need a set but I can’t even receive them until we are out of quarantine here which is tentatively set for mid April. Link to comment Share on other sites More sharing options...
buxmj Posted March 31, 2020 Share Posted March 31, 2020 Hope you are feeling better! Take care of yourself hope it gets better for everyone soon! Link to comment Share on other sites More sharing options...
87MJJeep Posted August 16, 2020 Share Posted August 16, 2020 On 3/14/2020 at 9:20 AM, SatiricalHen said: They can be repaired, the see I had were real bad, but I redid them. Sent from my iPhone using Tapatalk @SatiricalHen Exactly what material did you use to replace the rubber pieces? What is the best approach for pulling those plastic pieces from the cab? Does one end/side pop out easier? Mine don't want to budge, and I don't want to crack them them. Link to comment Share on other sites More sharing options...
SatiricalHen Posted August 19, 2020 Share Posted August 19, 2020 @SatiricalHen Exactly what material did you use to replace the rubber pieces? What is the best approach for pulling those plastic pieces from the cab? Does one end/side pop out easier? Mine don't want to budge, and I don't want to crack them them. Some rubber sheeting I bought on amazon. I have a bunch left over from that. It’s a little thicker than the factory stuff though. I used a couple screw drivers and carefully popped the side tabs out then go and pop the bottom tabs out and slide down kinda. I’ve popped 3 or 4 sets of them out now. Let me see if I can find the amazon order and find out exactly what I actually ordered. Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
87MJJeep Posted August 19, 2020 Share Posted August 19, 2020 6 hours ago, SatiricalHen said: Some rubber sheeting I bought on amazon. I have a bunch left over from that. It’s a little thicker than the factory stuff though. I used a couple screw drivers and carefully popped the side tabs out then go and pop the bottom tabs out and slide down kinda. I’ve popped 3 or 4 sets of them out now. Let me see if I can find the amazon order and find out exactly what I actually ordered. Sent from my iPhone using Tapatalk Thank you for the rubber tip and the removal advice! Link to comment Share on other sites More sharing options...
87MJJeep Posted August 25, 2020 Share Posted August 25, 2020 I have not re-installed my cab vents yet, but here they are. I am tempted to glue a little stick across the three tabs to ensure the flaps don't come off like the factory ones did. The rubber sheets are 1/16" thick or ~1.6 mm thick. I happened to have one survivor stock flap, and it measured 0.5 mm thick. I definitely wish this new rubber was a bit thinner. I used a 3/32" punch to make the holes. Link to comment Share on other sites More sharing options...
