Huge amount of parts (NJ)
70barracuda
Cleaning out my storage unit. Everything is OBO.  Feel free to make offers. If you want more pics just ask. Shipping on your dime. Electrical stuff I can't guarantee.
Door armrests. $25 (sold)
2wd manual center console. Cracked side, cb mount screwed in. $25
2.5 fan with clutch. $50
2.5 fan shroud. No cracks. $60
2.5 plastic valve cover. Side is all melted. $10
2.5 coolant jug. Didn't leak no cracks. $25
CPS. Worked when it was in my jeep. $25
Map sensor. Worked when in the jeep. $25
Idle adjuster. I pulled it apart and greased it and it worked better but not great. $20 (sold)
2.5 fuel injector. Worked when in the jeep. $30 (sold)
Clock delete plate. $10
2.5 air box with vacuum flapper in front. $50 (sold)
Mirrors. Glass is good. Paint super faded. Side clips are broken but stays on fine. $50
Evap charcoal canister. $50
Grey door panels. Pretty good shape. $100 (sold)
  • 2 months later...
  • 1 month later...
gray steering wheel ($50) and horn button (sold)
miscellaneous steering column parts, just message what you need and ill check (no intermittent wiper switch)
honey B pillars and good shape ($80 each)
Honey kicker panels($50) and A pillar panels ($50)
I was told this was honey but it looks more like almond when held up to compare, some broken back tabs but held fine for me ($60)
gray dash with glovebox. some wrinkles on top to left but otherwise in great shape ($200)
  • 3 months later...
A/c bypass pulley of an 88 4.0 ($60)
Navy blue rear window trim. 2 broken tabs. ($60)
Navy sun visor pad and clips ($20)
Parking brake handle, 3 broken wires ($50)
210,000 2.5 - $100.
Didnt smoke, made 89 hp on dyno last summer. It ran really well when pulled for ls swap
ax5 2wd trans -$100
Shifted good. 3rd clicked slightly if shifted at high rpm. Out of a 96 cherokee originally. About 150k on it.
Will seperate
Archived
