Adding AC
16 minutes ago, eaglescout526 said:
I recommend trying to stick with your era for your truck as it should make installation less of a headache down the road.
Thank you, I’ll keep an eye out for a Renix with AC. I’ll try and find the threads! Thank you guys!
47 minutes ago, eaglescout526 said:
If you can't find parts there is an 89 XJ at the AMC salvage I frequent that has the AC lines and brackets. I took the controls and dash wiring though.
I’ll defiantly most likely take you up on that. I’m looking at a MJ in the junkyard as we speak. It’s 2 hours away but has a brush guard and the AC components. About to head out .
Is that an '88 or '89?
