RookieComanche Posted February 21, 2020 Share Posted February 21, 2020 My last post made it seem that I was possibly getting a 3 inch lift kit, which I was; however, after further discussion with my dad (Who originally owned for quite a long time) spoke up saying we should hold off any lift kit if we're going to convert it to 4WD. Would it be worth it? Or will the conversion process render me needing a new lift kit. It sounds dumb, but I'm trying to consider as much money saving as possible. Link to comment Share on other sites More sharing options...
Pete M Posted February 21, 2020 Share Posted February 21, 2020 the lift and the conversion can be done independently of each other. A reason for doing them separately would be spreading out the cost. A reason for doing them together would be duplication of work. You'll need to undo a lot of the same nuts/bolts for both projects. Link to comment Share on other sites More sharing options...
RookieComanche Posted February 21, 2020 Author Share Posted February 21, 2020 Thanks, I assumed that, but Assuming makes me look stupid Link to comment Share on other sites More sharing options...
SouthernComanche Posted February 21, 2020 Share Posted February 21, 2020 Thanks, I assumed that, but Assuming makes me look stupid Going through the same process you are!!! To save some trouble and spread out costs cause I'm broke... I'm doing the front axle with 3in lift right now. Tires and wheels included everything cost be about $1100. Doing the front axle now will save me the trouble of getting the springs on there. I just sent them up with the axle easy peasy. The whole process is actually super easy. I'm having trouble right now with WJ knuckle steering; but thats only because I bought a modded axle. If you’re going stock to stock it should be bold in easy. Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
RookieComanche Posted February 21, 2020 Author Share Posted February 21, 2020 First off, nice Truck my guy! It probably would be wiser to spread out the costs as well here with my situation. Link to comment Share on other sites More sharing options...
mjeff87 Posted February 22, 2020 Share Posted February 22, 2020 4WD leaf packs will put your 2WD about an inch higher in the rear right from the start. Link to comment Share on other sites More sharing options...
Eagle Posted February 23, 2020 Share Posted February 23, 2020 Why do you want to lift it? Link to comment Share on other sites More sharing options...
