Hey! I've recently acquired this full blue cluster from a 1986 XJ V6!
However, I heard there are some compatibility issues. Is there anything important I need to know to get it installed?20200215_125146.jpg.6eb6466d18c810b7235cab6cce615fc9.jpg
Also, how can I take the needles out the cluster? I'm trying to pull the speedometer out and its loose but the needle is stuck in place.
Yeah, I won't use the tach anyways. Just nice to have all the gauges and looks better. I didnt take the cruise control, I can next time
3 hours ago, eaglescout526 said:
Nope! That system is all plug and "where the hell does that go?".
Yeah ... a.k.a. "Plug ... and play around"
Not the best photo but I took it apart and cleaned it up. The odometer is exactly 23,000 miles low. If the speedometer cable doesnt work, then I'll just swap in the speedo from my old cluster :holdwrench:20200215_191841.jpg.010ca0e74ddf63cb66fef41ddfc19dfa.jpgnot the mot then
Aaaaand I have tried that too. The Speedo isn't a direct swap either. If and when you get to removing your old cluster, look at the back of both of them and you will see how much different the mounting screw points are. You’ll need to get a cable for 84-86 as a swap for your cluster. Ill show you the backs of both clusters.
Sure. Make sure its in good shape and can be lubed. While your there you can get the cruise control stuff too. Actually...If you snagged the speed sensor you could just get a new speedo cable that is for cruise control and just use that as the cable just threads on to the speed sensor and since you have the adaptor already.
I know it sounds confusing and it kinda is. Which ever is easiest for ya.
Okay, thanks! Do you know where I can pick up an appropriate cable? The one from the car would be nice but the yard is only open on Saturdays, and I'd like to have this working sooner than that. I won't see my MJ for a month or two after this weekend :sad:
Why does the speedometer read 20 MPH in this photo but it read zero in your first photo?
Answer: Because you pulled the needle off and screwed it up. Why did you pull the needle? YYou DON'T need to pull the needle to "clock" the odometer.
The needle was moved about when I cleaned it up. After cleaning, it was at 20, then I pulled it, and put it back at 20. I am a newbie when it comes to cars, so as time goes on I'll quit doing stuff the stupid way :doh:
20 hours ago, CODriver said:
Oh, I always thought cruise control was only for automatics. Thanks for the info :thanks:
it works better with automatics, it keeps a constant speed by adjusting the throttle, shifting up or down when needed
in a manual all it does is hold the gas pedal for you, the act of shifting gears kinda defeats its purpose
