hakukamana Posted February 7, 2020 Share Posted February 7, 2020 Appears to be an 87' Short Bed. Just purchased, All Black Interior. Exterior is black primer. Bench seat. 5 speed manual 4x4, 4.0L, Renix. Here's the kicker, has the idiot light cluster in the interior, the title and the cluster mileage numbers match, 57,391, the mileage appears to be correct. Its not in pristine condition but appears to be in "Good condition" a little surface rust. I'll try to get some pictures, drove it home about 85 miles, at highway speeds seemed to be fine. Link to comment Share on other sites More sharing options...
eaglescout526 Posted February 7, 2020 Share Posted February 7, 2020 *X1 -Y1 3LV 2010.5 Fleet Loyalty Bonus ADL SKID PLATE GROUP AGJ Driver Assistance Group APA MONOTONE PAINT PACKAGE AWE BCQ Battery - 750 Amp Maintenance Free CBA BENCH SEAT - STRAIGHT BK CGX Head Restraints-Outboard Seating, RR CKA CARPETS - CLASS I SHORT PILE 8 - 12 OZ DDQ Transmission - 5-Speed Manual DMR 3.55 Axle Ratio DSA LIMITED SLIP DIFFERENTIAL ERB ENGINE - 4.0L I6 MPI GAS GAC ALL WINDOWS - TINTED GLASS GEC Window - Left Side, Front, Sliding GFD SLIDING RR WINDOW GPB DUAL - O/S MIRR PKG - LOW MOUNT - CHROME HCC HEATER W/UPR LEVEL VENTIL - TYPE II JAY Instrument Cluster w/Tach JGB Clock - Digital JHA WINDSHIELD WIPERS - DELUXE JJA CIGAR LIGHTER - FRT COMP LAP FUEL ECONOMY SHIFT INDICATOR LIGHT LMA HALOGEN HEADLAMPS MBF REAR BUMPER - STEP TYPE (BRIGHT) MDA FRT LICENSE PLATE ATTACH REQUIRED MFD BRIGHT GRILLE - TYPE I NAF HIGH ALTITUDE EMISS CONTROL PKG NMB ENGINE COOLING - STANDARD DUTY PXJ Diamond Black Crystal Pearl Coat QXJ Diamond Black Crystal Pearl Coat RAB Radio - AM/FM SBA POWER STEERING SCE STRG WHL - EURO/SPORT TYPE SUA TILT STEERING COLUMN TBB CONVENTIONAL SPARE TIRE TBL TIRE CARRIER - INSIDE WJD WHEELS - 15 X 7.0 STYLED STEEL XEA TOW BELTS XPF PROTECTIVE COATING AND REMOVER Build date 3/23/87 Body code JM61 Link to comment Share on other sites More sharing options...
High2by Posted February 7, 2020 Share Posted February 7, 2020 You can roll the mileage on the old clusters to match. According to the build sheet, it has a tach. Link to comment Share on other sites More sharing options...
eaglescout526 Posted February 7, 2020 Share Posted February 7, 2020 21 minutes ago, High2by said: You can roll the mileage on the old clusters to match. According to the build sheet, it has a tach. I have noticed a lot of build sheets say they have a tach. Makes me wonder if the code was originally for idiot lights. Link to comment Share on other sites More sharing options...
hakukamana Posted February 7, 2020 Author Share Posted February 7, 2020 If that is the case regarding roll over, that would mean that it was rolled over 999,999 + 50K= 57K? I wonder how long that would take with an electric drill and a speedo cable? Why would someone do that? I have trucks with 276k, 157K, and they are kind of testimony to the durability of the design. I would see no reason to roll over a 33 year old truck odometer. I looked at the title from the recent purchase, it indicated that the odometer mileage prior to this purchase was 52,168, and that was in 08-15-2017. Link to comment Share on other sites More sharing options...
Pete M Posted February 7, 2020 Share Posted February 7, 2020 I believe he's referring to the ease of which you can change the numbers to whatever you'd like. there should be a link to a how-to in the link in my signature. Link to comment Share on other sites More sharing options...
jdog Posted January 30, 2021 Share Posted January 30, 2021 Selling Dealer: BAY CITY JEEP-EAGLE Hilo, HI Link to comment Share on other sites More sharing options...
