Jtslick89 Posted February 7, 2020 Share Posted February 7, 2020 Received my new headliner from SMS. There is no old headliner (just completely missing). Anyways, long story short, I noticed that the A pillar trim on the drivers side is broken in the 2 torx screw areas (where the little circle hole cover is). Any recommendations on how to get the trim tighter since this broken area will be loose if i can't? Larger/longer bolt that sticks out and get rid of the decorative cover? Any other ideas? Link to comment Share on other sites More sharing options...
Jeep Driver Posted February 7, 2020 Share Posted February 7, 2020 I did not photograph it but I repaired the screw areas the same way. Epoxy and fiberglass strands. Link to comment Share on other sites More sharing options...
SVPete Posted February 7, 2020 Share Posted February 7, 2020 Same here. Chopped fiberglass and epoxy mix. Link to comment Share on other sites More sharing options...
ghetdjc320 Posted February 7, 2020 Share Posted February 7, 2020 I use a hot knife and melt the plastic back together. Link to comment Share on other sites More sharing options...
AZJeff Posted February 7, 2020 Share Posted February 7, 2020 Epoxy and some thin aluminum sheeting cut/bent to shape (and glued to the inside of the piece) works well for this type of stuff. I have done that on several spots, and on my door panels as well. Link to comment Share on other sites More sharing options...
