coman Posted January 23, 2020 Share Posted January 23, 2020 1987, Jeep Comanche, Laredo 4L, 6 cyl, Long bed Build date: Door tag is blank or worn off Current residence: Salina, Ks, Sold by Spradely Pueblo, Co Status: Runs great, Daily Driver Current owner: Patrick Harrington, “Coman” 204,000 miles on this body. New AutoZone remanufactured engine with only 18,000 miles. Electric windows and door locks. New: water pump, master cylinder and booster, alternator, distributor, sensors, washer pump, rear step bumper New engine. All peripheral components. New starter, Alternator, Injectors, Water pump, Fuel pump, Distributor, Brake booster, Master cylinder, Brake cylinders, Brake lines, Fuel regulator, Ignition module, Shocks, Rear bumper, Seat belts, JVC Stereo/speakers Misc: Tool rack Needs: IMHO Body was clear coated but needs repaint Some restore: Rust, floor pans, rockers Engine and frame cushions/bumpers, motor mounts etc. Replace tie rods Recover seats, new carpet Mods: remove C101 New Tires Link to comment Share on other sites More sharing options...
eaglescout526 Posted January 23, 2020 Share Posted January 23, 2020 *W7 Cloth Lo-Back Bckt/Red Accent Seats -YY 3LZ ADA LIGHT PACKAGE ADB PROTECTION GROUP PACKAGE ADL SKID PLATE GROUP AHL HEAVY DUTY INSUL PACKAGE APB TWO TONE PAINT PACKAGE - I APP TWO TONE PAINT PACKAGE AWH POWER EQUIPMENT GROUP BCQ Battery - 750 Amp Maintenance Free CAC BUCKET SEAT - LO BK CGW Air Bags - Front, Next Generation** CKA CARPETS - CLASS I SHORT PILE 8 - 12 OZ CUF FULL LENGTH FRONT CONSOLE DGQ TRANSMISSION-5SPD AUTOMATIC 5-45RFE DMR 3.55 Axle Ratio DSA LIMITED SLIP DIFFERENTIAL ERB ENGINE - 4.0L I6 MPI GAS GAC ALL WINDOWS - TINTED GLASS GEC Window - Left Side, Front, Sliding GFD SLIDING RR WINDOW GPB DUAL - O/S MIRR PKG - LOW MOUNT - CHROME HAA AIR CONDITIONING - FRONT HCC HEATER W/UPR LEVEL VENTIL - TYPE II JAY Instrument Cluster w/Tach JGB Clock - Digital JHA WINDSHIELD WIPERS - DELUXE JJA CIGAR LIGHTER - FRT COMP K60 BODY SIDE MLDGS - VINYL LBB COURTESY LAMPS (BELOW PANEL) LDA UNDERHOOD COMPT LAMP LMA HALOGEN HEADLAMPS LPE EXTERIOR CARGO LIGHT MBF REAR BUMPER - STEP TYPE (BRIGHT) MCA FRONT BUMPER GUARDS MCB REAR BUMPER GUARDS MDA FRT LICENSE PLATE ATTACH REQUIRED MFD BRIGHT GRILLE - TYPE I NAF HIGH ALTITUDE EMISS CONTROL PKG NFA TANK - 20 GAL FUEL NHB HVY DTY/AUX TRANS OIL COOLER NHM AUTO SPEED CONTROL NMB ENGINE COOLING - STANDARD DUTY PYM QYN Giallo (Yellow) RAF Radio - AM/FM Cassette SBA POWER STEERING SCG LEATHER STRG WHEEL - EURO/SPORT TYPE SUA TILT STEERING COLUMN TBB CONVENTIONAL SPARE TIRE TBL TIRE CARRIER - INSIDE WJD WHEELS - 15 X 7.0 STYLED STEEL XEA TOW BELTS XJH LOCKING FUEL FILLER CAP Well optioned MJ Build date 6/15/87 Body code JP62. Made at just the end of the cusp of the 87 model year Link to comment Share on other sites More sharing options...
89 MJ Posted January 23, 2020 Share Posted January 23, 2020 Is this like the grille guard that @Red Mistress wanted? Link to comment Share on other sites More sharing options...
eaglescout526 Posted January 23, 2020 Share Posted January 23, 2020 25 minutes ago, 89 MJ said: Is this like the grille guard that @Red Mistress wanted? Kinda. He wants the one that has the winch built on to it. This one is the design from AMC. Now that one I would like too have but it seems really easy to fabricate out of some pipe. Link to comment Share on other sites More sharing options...
jdog Posted January 30, 2021 Share Posted January 30, 2021 Selling Dealer: DALE SPRADLEY MOTORS Pueblo, Co Link to comment Share on other sites More sharing options...
