coman
Everything posted by coman
Thanks very much. Comanche club rocks
The motor works and surely needs cleaning. Can you note a reference in your log that I can follow?
I am reading your Comanche build log. Nice work. Detail is supreme. I just got to the place where you mention the window. If I could find a snake replacement I might be happy.
The snake is damaged. Window will rise to a certain point then stop. Motor continues to run. Some splines on the snake are missing.
Snake frame is different. Mounting flange on motor and other hole patterns are wrong. Electrical connector is wrong.
The drivers side power window needs replacement. I have ordered 2 parts (1 from dorman and 1 from salvage). Neither fits. The car part listing says that Cherokee is compatible but its not. Is the common model the Wagoneer in 1987? The assembly on the bottom is what I removed. The other one is the Dorman part.
Hello Comanche Chieftains. 87 Comanche: I replaced the ignition power switch on the steering column. This solved the immediate issues but....How do I fix it so there is not a melting switch failure again? For several days after the replacement I have burning and melting smells. I read about poor designs but can it be fixed? I am running out of nickels and dimes.. I do wish to sell it to get a Grand Cherokee that will meet my needs. Straight trade is OK.
Turn Signals not working/Electrical problems
coman replied to Rhys Chalmers's topic in MJ Tech: Modification and Repairs
Good afternoon. My 87 Comanche had the same issues. I did most of the ground refresh list with no improvement. I also removed the connector block under the hood. No change. Finally the forum masters found a reference to the main power switch connected to the ignition key switch. This switch is on the steering column. It wasn't much fun to replace and I still need to adjust the whole thing but the intended functions have been fixed. Now my brake lights are always on unless I unplug 1 brake switch wire. I noticed the switch was really warm. Good luck to you. Hope this helps. -
TY. Please close
How do I kill the wipers? The switch is bad and the wipers go all the time... Until I can replace the switch.
Pics and praise.... Everything works now except the horn. Almost ready to sell. Thanks Cruiser54. Case closed. Hail Comanche Club!
You da mack. Flawless victory
OK, I am tracking the problem down. The symptoms: No horn, blinkers, radio, heater/ac or wipers. They all used to work and they all stopped at the same time. The truck runs fine. The flashers work fine. Fuses all tested for continuity. Horn replaced, Blinker switch removed and cleaned. Radio lights up only for the eject function then goes dark again. Other actions: Remove C101 Refresh grounds: drivers side under dash and near the washer tank/air cleaner. Passenger side both at blower and near the relay bank. Engine (center) to firewall. Engine block stud, (2 wires here). I reviewed the diagrams supplied by hosts and others (TY). A bad ground seems likely or a common power relay? Any others thoughts? TY in advance.
I am missing this. Any referrals? TY P
1987, Jeep Comanche, Laredo 4L, 6 cyl, Long bed Build date: Door tag is blank or worn off Current residence: Salina, Ks, Sold by Spradely Pueblo, Co Status: Runs great, Daily Driver Current owner: Patrick Harrington, “Coman” 204,000 miles on this body. New AutoZone remanufactured engine with only 18,000 miles. Electric windows and door locks. New: water pump, master cylinder and booster, alternator, distributor, sensors, washer pump, rear step bumper New engine. All peripheral components. New starter, Alternator, Injectors, Water pump, Fuel pump, Distributor, Brake booster, Master cylinder, Brake cylinders, Brake lines, Fuel regulator, Ignition module, Shocks, Rear bumper, Seat belts, JVC Stereo/speakers Misc: Tool rack Needs: IMHO Body was clear coated but needs repaint Some restore: Rust, floor pans, rockers Engine and frame cushions/bumpers, motor mounts etc. Replace tie rods Recover seats, new carpet Mods: remove C101 New Tires
What is the value of this resistor?
I have found a connecter on the passenger side under the dash. It used to have something between 2 contacts. I can see the wires but what is supposed to be there? The connecter is marked 24 PED.
Thanks all for the great pics. Especially for the colored coded one.
Thanks to all.
87 Comanche all those relays: Is there a diagram available that lists the relays by location? Here are passenger and drivers side pics. Passenger side bank and another one near the ac hose. Thanks
