Bobbed bed with hitch receiver?
good question.  To me seems a bit odd to hack off the bed for better clearance and than keep the thing that hangs down the most.  :dunno:
Do you plan to tow with it?  or just use it as a recovery point?
I bobbed it cause i kept getting stuck on things from the length like turn arounds and things. i use my truck often and would like to keep the tow ability with it so i was thinking about mounting it to the inside of my frame rails with some plating for reinforcement. Do yall think that would work ok?
Proper design will allow that, yes. :L:   When fabricating your new brackets, I suggest integrating the upper shackle bolt for extra strength.
In an interesting pepsi twist, our '16 Durango integrates the factory hitch right into the steel bumper structure.  I literally had to discard the old bumper when I installed it. :dunno:
Consider something similar-
Cross bar is 3"x.25 wall tube, everything else is 3/8 plate.
I did not mount the receiver high for two reasons, I wanted to keep the tag where it belongs, secondly- many hitch designers/companies split the cross bar into two pieces, I don't like that, it weakens the cross bar, IMO.
But, you certainly can so that you don't lose ground clearance.
Also, if you add a 2" receiver.......it IS a hitch, it is NOT simply a recovery point........design it to tow, just because you won't doesn't mean someone else won't.
If designed properly, I see no reason to incorporate the shackle bolt.....in fact, I would not.
