Jeep 87 Comanche Relays
Bottom photo:  Electrical Cooling Fan
Top photo:
Keep in mind the Relay Blocks can be assembled many different ways. This photo would be factory.
Top photo shows a relay floating in mid air. This is not factory. Need to trace wires. Possible add on Headlight Relay.
Driver's fender is fan control relay.
The passenger fender tends to be a crap shoot.15787895350022860679098714434230.jpg.7a2b4063430d554aaf69ba97ab535f2d.jpg
The four in a row are.
Oxygen heater relay
Fuel pump relay
Power latch relay
Ac clutch relay
They don't seem to always be in the same order. I followed the wiring diagram and checked wire colors to see what mine were.
mj1988electricalmanual_(1).pdfpdf
That is the 88 electrical manual I believe it's the same as 87.
The one by the AC hose someone has added.
I'm gonna jump in and ask a related question. On the passenger side. All those relays and wire connections, is there supposed to be a cover or box of some kind they go in? Mine are all just flopping around
Sent from my LM-V405 using Tapatalk
Do your relay blocks have that pointee thing on the bottom of photo. Also are your relay block locked together with one another. Relay blocks slide together. Pointee thing goes in little hole on the relay cover bracket.
Too technical for me........the terminology is over my head....
