Chebby Drop Shackles
The ones I have are definitely wider at both ends. Eyeballed them under the truck today and the frame side is as noted above @1/8" + wider than the mounts. Spring side looks like it will need 1-2 washers on each side of the spring eye to have a tight fit. I got these a couple years ago, can't even remember where from, i.e. if from a retailer or from an individual.
10 hours ago, saveevryjp1998 said:
I have a third set from there Pete still in the box. I might get a measurement and post pics but it was super easy to fix. If irc the sleeve sticks past the poly bushings each side like 3/16" on the brand I bought from auto zone. All 3 sets were the same brand.
But poly bushings aren't OEM spring bushings, they're aftermarket. As far as I'm concerned, all bets are off with aftermarket.
12 hours ago, saveevryjp1998 said:
By now surely most people have put new aftermarket leaf packs or bushings in after 25 plus years especially since nos one isn't an option for most folk.
Whyever would you say that? I haven't changed the bushings or the leaf packs in any of my MJs or XJs, and I have no intention of doing so (with the possible exception that I might add a leaf to the rear of the 2WD MJ to bring it up to 4WD ride height).
"And stop calling me Shirley."
Got these mounted up today. Had to get my shop to install them, upper bolts were seized to the bushing pin. Pretty sure they were OE and never removed. Shop did not say anything about having any difficulty going in on the frame side, so all good. I haven't measured yet but it is very noticeable, I think I got a full 1.5" out of them. They are 7.5" eye to eye.
