Virginia Posted November 21, 2019 Share Posted November 21, 2019 And now it's next to impossible to roll up and down. What could bind it? Link to comment Share on other sites More sharing options...
Warren Mohler Posted November 21, 2019 Share Posted November 21, 2019 are both sides in the channel? Link to comment Share on other sites More sharing options...
MiNi Beast Posted November 21, 2019 Share Posted November 21, 2019 This part of your leaking issues? Link to comment Share on other sites More sharing options...
SVPete Posted November 21, 2019 Share Posted November 21, 2019 I assume you had to pull the triangle widow to replace it? If so, take the door panel off and adjust the bottom mounting bolt for the triangle window. Loosen the bolt and push the channel towards the front of the truck and re-tighten the bolt. Obviously, then check window for operation. If you didn't pull the triangle window, still worth checking. I had the same problem the first time I replaced a window regulator. Link to comment Share on other sites More sharing options...
Virginia Posted November 25, 2019 Author Share Posted November 25, 2019 I'll pull the panel and check the triangle. It was a body shop that did this. I'd take it back but it takes FOREVER to get it back. I'll look at the channels and no, it's not part of my leaking issue. Link to comment Share on other sites More sharing options...
Warren Mohler Posted November 25, 2019 Share Posted November 25, 2019 if glass is in channels front and rear you might try spraying silicon into channels first give it a generous shot so it will run down the length of channel this might help a lot. if it doesn't door panel will have to come off. Link to comment Share on other sites More sharing options...
Virginia Posted November 25, 2019 Author Share Posted November 25, 2019 13 minutes ago, Warren Mohler said: if glass is in channels front and rear you might try spraying silicon into channels first give it a generous shot so it will run down the length of channel this might help a lot. if it doesn't door panel will have to come off. Thanks Link to comment Share on other sites More sharing options...
