Header panel repair?
Anyway, how have you repaired bolt locations when the fiberglass breaks off? I'm removing mine to remove the front fender.
Thank you for your help.
(I asked for the name of this earlier)
Edited by COM86
Unknown name.
I've used JB weld in the past and it kinda works until you take it off again.  The more times you take it off, the more it breaks.  From my experience you can "fix" it about 3 times before it's done for good.
I learned the lesson of never remove the nuts from there, instead pull the bolts out of the metal angle bracket and leave it attached to the header panel to avoid messing with the studs in the fiberglass.
