jeeptec1 Posted November 3, 2019 Posted November 3, 2019 Has anyone used or installed the rough country HD steering kit? Sent from my iPad using Tapatalk
Smokeyyank Posted November 3, 2019 Posted November 3, 2019 Pass......steering is a fickle mistress and RC isn't going to be the standout company worth spending money on. What are you running on your current set up? Most times a ZJ or solid tie rod is enough.
jeeptec1 Posted November 3, 2019 Author Posted November 3, 2019 Pass......steering is a fickle mistress and RC isn't going to be the standout company worth spending money on. What are you running on your current set up? Most times a ZJ or solid tie rod is enough. Mine is 100% stock at moment. Early MJ with the small drag link and tie rod at pitman arm. Sent from my iPad using Tapatalk
jeeptec1 Posted November 3, 2019 Author Posted November 3, 2019 Lift and tire size? 3 inch lift and 31’s future plans 4.5 lift soon. when the 31’s wear out then 33’s with cut out flares. Sent from my iPad using Tapatalk
Smokeyyank Posted November 3, 2019 Posted November 3, 2019 Zj or aftermarket solid tierod would be fine. No need to do anything else really. WJ setup will be the best all around upgrade but depends on your budget.
75sv1 Posted November 4, 2019 Posted November 4, 2019 I have the WJ big brake upgrade. I went with Ruff Stuff's Chevy 1-ton upgrade. I think I have it under the knuckles. I did use Rusty's OTK Trac Bar. I do have an Ironman 4X4 Fabrication OTK Trac bar kit on order. Might look at Ironman 4X4 Fabrication. A bit $$$, but I don't think people complain about the parts. I have not run the upgrade 'Y' steering upgrades though.
