hakukamana Posted November 3, 2019 Share Posted November 3, 2019 10x2.5 rear brakes Black vinyl floor covering Command-Trac Part time 4WD 230MM Front axle 3.07 rear gear ratio Bright Windshield Moldings AM MTR Radio Skid plate group Straight Back Bench seat 5-Speed Manual Transmission Dana 44/226MM Rear axle Anti-Spin Differential Rear Axle Left Manual mirror High Altitude Emissions 15x7.0 steel wheels Rear spring Group I Left front spring group VIII Right Front spring group VII Low series tracking Sold new 12-17-88 Color is Silver???? Mileage 230K speedo is not working Location Captain Cook, Hawaii Runs and drives Link to comment Share on other sites More sharing options...
eaglescout526 Posted November 3, 2019 Share Posted November 3, 2019 Whoa. How did you get your build sheet? Link to comment Share on other sites More sharing options...
hakukamana Posted November 3, 2019 Author Share Posted November 3, 2019 I checked the Chrysler vin check registry it came up. From what I understand pre98' is a hit or miss situation. Someone had to enter the data into the database. I guess after 98 Jeep went to a fully digital format and it automatically updates the database with build info. Link to comment Share on other sites More sharing options...
hakukamana Posted November 3, 2019 Author Share Posted November 3, 2019 Here's the link: https://fcacommunity.force.com/RAM/s/equipment-listing Getting a Jeep Build Sheet for Jeeps Built Before 1998 Here is where it gets really challenging to find your Jeep build sheet. But we’ve heard stories from jeepers who have been successful. Here are 2 things you can try: Option 1: First go ahead and try the steps above. John at Chrysler told me that sometimes folks are able to get their Jeep build sheet using that method if the records were input by someone at Jeep. He explained that factory build sheets prior to 1998 are fairly obscure and yet some of them managed to make it into the system. It really depended on the vehicle and model and which sites were active prior to 1998. At that time Jeep just wasn’t keeping all of the records digitally. It wasn’t until 1998 that all Jeep build sheets were required to be input. Option 2: Contact FCA Historical Services. This is really more for vintage vehicles, but John said that it is possible they may have build sheets for Jeeps built prior to 1998 and that he had heard of some success stories in finding them through that method. If you contact them, make sure you let them know you are looking for your factory Jeep build sheet and provide them with the 17 character VIN (Vehicle Identification Number) of your Jeep. Here is the contact info for FCA Historical Services: Mailing address: FCA Historical Services 12501 Chrysler Freeway CIMS: 410-11-21 (That is their Department Code) Detroit, MI 48288 Email: danielle.szostak@fcagroup.com (Please allow 5-7 business days for a response.) Fax: Yes, as of my conversation with John they still use a fax machine. But if you want to go that route, the fax number is (313) 252-2928. Link to comment Share on other sites More sharing options...
Ωhm Posted November 3, 2019 Share Posted November 3, 2019 39 minutes ago, hakukamana said: High Altitude Emissions I wonder what that means. Offset CPS???? Different ECU???? Different CCV???? Link to comment Share on other sites More sharing options...
eaglescout526 Posted November 3, 2019 Share Posted November 3, 2019 Yes, that is for the High altitude CPS. Let me pull up starparts and compare if you don't mind? Link to comment Share on other sites More sharing options...
hakukamana Posted November 3, 2019 Author Share Posted November 3, 2019 I know Cruiser said at one time I think that there was an option for a high altitude CPS. He would be the one to know. It was a Zone 71-Los Angeles truck It also had a Perforated Steering wheel w/Red Stitching Interior is gray Solid back window Link to comment Share on other sites More sharing options...
eaglescout526 Posted November 3, 2019 Share Posted November 3, 2019 *X2 TRIM STYLE X2 - VINYL BENCH -SA Charcoal 171 Zone 71-Los Angeles 1AA U.S. Dealer Retail 5AL Low Series Tracking ADL Skid Plate Group APA Monotone Paint BAQ 61 AMP ALTERNATOR BCX Nickel Metal Hydride Battery BGA Power Front Disc/Rear Drum Brakes BJA STD DUTY FRT DISC BRAKES BKP 10x2.5 Rear Drum Brakes CBA Straight Back Bench Seat CKJ Black Vinyl Floor Covering CSR Passenger Assist Handles CUM Mini Floor Console DBB All Manual Transmissions DDX 5-Speed HD Manual Transmission DHN Command-Trac Part Time 4WD System DJH 230MM Front Axle DMM 3.07 Rear Axle Ratio DRK Dana 44/226MM Rear Axle DSA Anti-Spin Differential Rear Axle EAA All Engines EAF ALL FUEL INJECTED ENGINES-GAS ERB ENGINE - 4.0L I6 MPI GAS GAC Tinted Glass Windows GBB Tinted Windshield Glass GCB Front Door Tinted Glass GEH Fixed Door Vent Glass GNA Rear View Day/Night Mirror GRV Left Manual Mirror GUA Open HCD Do Not Use - See HCA JAA Instrument Panel JAY DO NOT USE - See JP, KA classes JBF Instrument Panel Black Bezel JCA 85 MPH Primary Speedometer JGB Digital Clock JHA Var Intermittent Windshield Wipers JJA Cigar Lighter JKB MOPAR Hood Lock K3Z STRIPE/BADGE/MOLDING/COLOR KWX DK QUARTZ - BADGE - "INTREPID" - DECKLID LAF Seat Belt Alert-Driver Seat only LAP Shift Indicator Warning Lamp LBC Glove Box Lamp LCJ DOME/READING LAMP B-PILLAR LMA Halogen Headlamps MB1 Black Front Bumper MBJ Black Powder Coated Front Bumper MDA Front License Plate Bracket MFF Black Grille MHB Bright Windshield Moldings MMC Rear Door Solid Window Insert MMG Belt Moldings MMJ DRIP TROUGH MLDG - TYPE I NAF High Altitude Emissions NBA LIGHT DUTY CYCLE NBK EVAP Control System NDA Catalytic Converter NF5 Fuel Tank - 23 Gallon PA2 STERLING SILVER M CC PRIMARY PAINT - HA2 QA2 STERLING SILVER MC SECONDARY PAINT - HA2 RAA All Radio Equipped Vehicles RAC AM MTR Radio RCA 19 SPKRS SRT High Perf Audio SBA Power Rack and Pinion Steering SCB Perforated Steering Whl w/Red Stitch SFB Front Heavy Duty Shock Absorbers SGB Rear Heavy Duty Shock Absorbers SUA Tilt Steering Column TAA All Tires TBB Full Size Spare Tire TBM Tire Carrier Winch TRP 225/70R19.5G All Pos Traction Tires WJD 15X7.0 Styled Steel Wheels XBS Pickup Box XEE Fuel Tank Skid Plate Shield XEF Transfer Case Skid Plate Shield XEU Front Suspension Skid Plate XFA -35F Protection Anti-Freeze XPF Protective Coating and Remover YAA Build To U.S. Mkt. Specifications YGA Without Billable Fuel YGB 1 Additional Gallons of Gas Z01 Rear Spring Group I Z58 Left Front Spring Group Viii Z5B Payload Rating - 1800# Z77 Right Front Spring Group VII Now you are correct about the build sheets being inaccurate. I made this disclaimer before. But its due to Chrysler reusing codes and such. Prior to 1989 like yours is a hit or miss on data. 1988 and down when AMC was still around weren't filed away properly so some data is still lost. Build date: 10/16/88 Body code JL62 Link to comment Share on other sites More sharing options...
hakukamana Posted November 3, 2019 Author Share Posted November 3, 2019 Whats low series tracking???? Link to comment Share on other sites More sharing options...
eaglescout526 Posted November 3, 2019 Share Posted November 3, 2019 Who knows. Like I said we have found that Chrysler has been recycling codes ever since they acquired Jeep. We compared another members build sheet and found some codes to be the same but different descriptions for the code. Link to comment Share on other sites More sharing options...
jdog Posted March 29, 2021 Share Posted March 29, 2021 Selling Dealer: BAY CITY JEEP-EAGLE Hilo, HI Link to comment Share on other sites More sharing options...
