Yellowtonka2 Posted October 29, 2019 Share Posted October 29, 2019 1986 Comanche Long bed 4x4 4.3 v6, 700r4 transmission I do not have the build date as the sticker is worn off. Located in south east North Carolina This is my project that is nearing its end. Almost road ready. Dark brown metallic exterior, tan interior, column shift auto. Vinyl bench seat. 6” lift, 35” tires, aluminum radiator, WJ booster, master cylinder, hub assemblies. Truck lite headlamps and custom front and rear bumpers. Link to comment Share on other sites More sharing options...
fiatslug87 Posted October 29, 2019 Share Posted October 29, 2019 Nice, pictures of the engine? Link to comment Share on other sites More sharing options...
Yellowtonka2 Posted October 29, 2019 Author Share Posted October 29, 2019 It still needs to be cleaned up, but it is now running and driving under its own power. Link to comment Share on other sites More sharing options...
eaglescout526 Posted October 30, 2019 Share Posted October 30, 2019 *ZZ TRIM STYLE ZZ - PLASTIC BUCKET SEAT -ZZ BAC 75 AMP ALTERNATOR BCQ Battery - 750 Amp Maintenance Free CGX Head Restraints-Outboard Seating, RR CKA CARPETS - CLASS I SHORT PILE 8 - 12 OZ DGF H D A904 AUTO TRANS DMN 4.78 Axle Ratio EFB ENGINE - 2.8L GM 6CYL HAA AIR CONDITIONING - FRONT HCC HEATER W/UPR LEVEL VENTIL - TYPE II K60 BODY SIDE MLDGS - VINYL LMA HALOGEN HEADLAMPS MDA FRT LICENSE PLATE ATTACH REQUIRED NAA ESA W/CATALYST (EXC CALIF SYSTEM) NMB ENGINE COOLING - STANDARD DUTY SBA POWER STEERING Build date: 11/5/85 Body code:JL62 Link to comment Share on other sites More sharing options...
89 MJ Posted October 30, 2019 Share Posted October 30, 2019 48 minutes ago, eaglescout526 said: DMN 4.78 Axle Ratio Is this accurate?!? Link to comment Share on other sites More sharing options...
Yellowtonka2 Posted October 30, 2019 Author Share Posted October 30, 2019 Honestly, I am not sure. I haven’t dug into the diffs yet. But I am sure that I will before to long. It has 288,000 miles on them. Link to comment Share on other sites More sharing options...
eaglescout526 Posted October 30, 2019 Share Posted October 30, 2019 25 minutes ago, 89 MJ said: Is this accurate?!? If it has an AMC 20, probably Link to comment Share on other sites More sharing options...
Pete M Posted October 30, 2019 Share Posted October 30, 2019 I've never heard of a 4.78 ratio so I'm doubtful. but you MUST do a full build thread! we need details and way more pictures! Link to comment Share on other sites More sharing options...
