I have an 89 Comanche 2 wheel drive I’m having issues with finding front end parts is there a good web site to go to with reasonable prices to get front suspension parts?
Considering my front end is starting to shake when I start to pick up speed to was looking to change everything
What kind of front end parts do you need? And where are you located? I'm having a hard time thinking about anything on the front end that is hard to get and can't think of anything, unless youre in another country (not the USA). Assuming youre in the US, rockauto.com generally has the best prices over a broad range of brands and choices. And any parts store near me can get whatever I need usually within a day if I don't want to wait for an online order. Then theres a plethora of aftermarket companies making upgrade parts. You might get more results on any of these by searching the same year Cherokee XJ. Some places don't list the Comanche, even though all the front end parts are the same.
I live in ny and when I ask for a part it’s not listed or can’t get it’s like the idiots around here don’t know what there looking for. It’s getting frustrating with these part stores
Instead of just throwing parts at it blindly, why not figure out what's causing the problem and start there?
You say the front end starts to shake when you pick up speed. What does that mean? Is this a slight shimmy, or is this death wobble? Does it happen when your speed increases from 20 to 25 MPH? From 25 to 30? How about ... does it start to shimmy at between 52 and 55 MPH, and then goes away when the speed gets over 60 MPH? A shimmy at 55 MPH that goes away above 60 is tire balance, and there is no combination of parts you can replace to correct for tire balance.
Quote
Autozone, Advance Auto, and NAPA all offer on-line parts lookup. Have you tried looking up the parts yourself?
The FRONT suspension components are shared between the MJ and XJ so it may broaden your results by looking under XJ.
