I have a 91 with factory buckets and mini console. I switched to a full xj console years ago but want to switch back and add a third seat for my little one.
I have seen the Dakota seat options but am un clear if it mounts separate or requires the passenger seat.  Obviously a seat/console would be best!  Has anyone added something with factory buckets?
thanks
I believe the Dakota seats need a crossbar support across the rear in order to work, so I don't think you can just use the 40/20 by itself if that's what you were thinking.
Here is one example using newer style Dakota seats (I like the look of these).  https://comancheclub.com/topic/20681-installed-2005-dakota-bench-pics-inside/
Another using the older Dakota seats. https://comancheclub.com/topic/55237-how-i-installed-dakota-seats/
Dakota mounting example, although I don't think the mount ever got produced for anyone else. https://comancheclub.com/topic/54132-dakota-seats-to-stock-comanche-mounts/
Another option depending on age of passenger. https://comancheclub.com/topic/41652-seats-who-has-what-in-their-mj/?do=findComment&comment=430679
Doesn't really deal with center, posting as option for others - they look good in there too. https://comancheclub.com/topic/25441-02-grand-am-gt-2-dr-seats-in-a-comanche-with-pics/?tab=comments#comment-263358
My factory buckets are tapped out for life or everyone else lies about liking them :) I think they are brutal. Either way I'm looking to replace mine, so I've been searching the site quite a bit for seat options, all of the above links have pretty good clear pictures of how they were mounted too.
Probably a couple of the above should be added to the DIY Master List https://comancheclub.com/topic/48710-diy-projects-writeups-master-search-index/
