Axel shafts
I have a 91 4.0 4wd and while changing my brakes deciced to change the hub and axel u joints... so obviously I bent the ears on the yokes when trying to remove the u joints... does anyone happen to know the part numbers for the front inner and outer yokes on both the driver and passenger side off hand?
Thanks guys
Sent from my SM-G973U using Tapatalk
With disconnect
(1)5252145. Shaft Assembly axle Rt. Number supersedes to 04797135
(2)5252585. Shatt Assembly axle Lt. Number supersedes to 04874303
Without disconnect.
(1)5252584. Rt w/o Anti-lock brake system. Number supersedes to 4874302
(2)5252585. Lt w/o Anti-lock brake system. Number supersedes to 4874303
Thanks guys
Go pull the axle shafts from this- https://www.lkqpickyourpart.com/locations/LKQ_Pick_Your_Part_-_Chattanooga-217/recents/
2 hours ago, madog7200 said:
Thanks guys !!
I just checked that link I posted.........does not take you to the '98 XJ they have listed.
D30 axle shafts will interchange throughout the years, get a pair of later shafts. Take your old ones otherwise they will charge you a core.
I actually found a guy out of New York that had some pretty good prices with free shipping on orders over 99 bucks.... I paid 210 for the passenger assembly in Spicer brand, same part o'Reilly's wants 400 for
Dennysdriveline out of new york.... I had questions and actually spoke to denny himself... they are very accommodating!
