knever3 Posted May 25, 2019 Share Posted May 25, 2019 I need a door check bracket that bolts to the body, does anyone know if this is available new? I don't want to go used if I can order one. I drilled out the broken bolts but the bracket is broken. Sent from my SM-G920P using Tapatalk Link to comment Share on other sites More sharing options...
rylee144 Posted May 25, 2019 Share Posted May 25, 2019 i this what your after ? https://www.ebay.com/p/Door-Check-Strap-Crown-55235571AB/229968517?iid=372015178517 Link to comment Share on other sites More sharing options...
Jeep Driver Posted May 25, 2019 Share Posted May 25, 2019 19 minutes ago, rylee144 said: i this what your after ? https://www.ebay.com/p/Door-Check-Strap-Crown-55235571AB/229968517?iid=372015178517 No, he needs the jamb side bracket. You are not going to find that new. Junkyard. Link to comment Share on other sites More sharing options...
Strokermjcomanche Posted May 25, 2019 Share Posted May 25, 2019 https://www.ebay.com/itm/OEM-Mopar-Door-Check-Bracket-For-1984-2001-JEEP-CHEROKEE-XJ-55002361/401713175491?epid=1411222225&hash=item5d87f89bc3:g:V8oAAOSwFpVcb1JA you can buy a complete set of 4 for $20 on eBay too . Link to comment Share on other sites More sharing options...
Jeep Driver Posted May 25, 2019 Share Posted May 25, 2019 Image that. Link to comment Share on other sites More sharing options...
knever3 Posted May 25, 2019 Author Share Posted May 25, 2019 Sweet! Thanks guys!Sent from my SM-G920P using Tapatalk Link to comment Share on other sites More sharing options...
