Does anyone know if 2dr XJ buckets and brackets will bolt right into an MJ? If not, what kind of modification will it take?
Thanks in advance!!!
Brackets will not work, regardless of year.  The seats will work, and are preferred over 4 door XJ seats because they flip forward like the stock bench seat for access behind the seat.  But the seats only work up to a certain year, then they changed.  Not sure the exact year.  If the bolts that hold the bracket go straight down into the floor, they work.  If the front mounting bolts go in from the front (pointing back, horizontally), that is the later design.
Through '94.
Also, all bucket seat parts through '94 can be swapped like legos.
