Renegade Posted September 11, 2007 Share Posted September 11, 2007 Basically I want to remove the tailpipe. I have a very solid exhaust system now. Looks like the previous owner bought oem prebent tubing with all the factory hangers & such. Looks almost new, kinda hate to mess with it.....but I just threw on a cold-air intake & want to install a Magnaflow muffler to gain a few ponies. I can slip the muffler onto the existing pipe, but I am thinking of going back about a foot behind it(where there is a nice hanger) & putting on a turndown & calling it good. I could get rid of about 5 feet of pipe with 5 tight bends in it. My biggest concern is killing my torque. I did this on my TJ & it lost all low-end power. I put the tailpipe back on & it runs great(when it ain't smashed shut from rocks-why I removed it in the first place). Also don't want it to sound like crap. Opinions???? Link to comment Share on other sites More sharing options...
FxRacing282 Posted September 11, 2007 Share Posted September 11, 2007 if you shorten your exhaust i would change the diameter of the pipe to compensate for the high flow "muffler" Link to comment Share on other sites More sharing options...
Renegade Posted September 11, 2007 Author Share Posted September 11, 2007 To maintain some backpressure? Link to comment Share on other sites More sharing options...
TNT Posted September 11, 2007 Share Posted September 11, 2007 My 4.0 HO has a Borla header, downpipe, high flow cat and a 40 series Flowmaster. It flows way better then stock. I didn't notice much if any lost of torque. The mid range to top end horsepower gain was noticeable. I also gained one mpg. Removing the taper in throttle body really helped. It eliminate the trans hunting from OD to D on hills. The throttle response is great and power was gained from the bottom to the top end. It was a great compliment for the exhaust. Link to comment Share on other sites More sharing options...
DirtyComanche Posted September 11, 2007 Share Posted September 11, 2007 There's enough restriction in the stock downpipe to provide for low-end exhaust scavenging. As long as it's got that crushed part in it to clear the D/S. Besides, do a couple more intake side mods and it won't matter if the exhaust flows way gooder. Link to comment Share on other sites More sharing options...
pingpong Posted September 11, 2007 Share Posted September 11, 2007 Pong has nothing but a stock down tube, aftermarket cat, and a glasspack with a small turn down. I think when I got everything new it was less then 125 bucks, and I have had no issues with it Link to comment Share on other sites More sharing options...
Renegade Posted September 12, 2007 Author Share Posted September 12, 2007 Cool. That's what I wanted to know. I will save the tail section in case I need to reinstall it. Link to comment Share on other sites More sharing options...
Eagle Posted September 12, 2007 Share Posted September 12, 2007 Opinions???? Your concern is valid. Some years ago, when the original exhaust went in my '88 XJ, I took it to my brother who at the time was managing a Speedy muffler shop. He talked me into upgrading to a 2-1/2" system with a turbo muffler. I was always sorry, and couldn't wait for it to rust out so I could justify getting rid of it. It sounded great, I admit ... but I lost torque, I had to downshift more for hills (5-speed), and I dropped about 2 MPG. When it did finally rust out I replaced with OEM-replacement muffler and 2-1/4" pipes, and got my torque and gas mileage back. No more aftermarket exhausts for me. Link to comment Share on other sites More sharing options...
FxRacing282 Posted September 12, 2007 Share Posted September 12, 2007 To maintain some backpressure? umm yes. no back pressure = no torque Link to comment Share on other sites More sharing options...
87manche Posted September 12, 2007 Share Posted September 12, 2007 mine has an oem walker muffler with a turn down immediatly after it's outlet. it's not been a problem. Link to comment Share on other sites More sharing options...
pingpong Posted September 12, 2007 Share Posted September 12, 2007 I like mine for the simple fact I can walk into any Advance, or Napa and buy all my stuff off the shelf with no special ordering. Everything is kinda generic Link to comment Share on other sites More sharing options...
CWLONGSHOT Posted September 13, 2007 Share Posted September 13, 2007 I also got tired of crushing mine. But I also do not like all the loud resonance that you get from exiting the exhaust under the bed of the truck. My solution was to wxit it out the side, Just in front of the pass side tire. CW Link to comment Share on other sites More sharing options...
Renegade Posted September 13, 2007 Author Share Posted September 13, 2007 I was considering a side exit. The more I think on this, I think I'll just slip in the performance muffler & see how I like it. It's 2wd, so the tailpipe won't see trail damage, but it is already hitting the rear spring-eye bolt since the lift springs changed the "angle of the dangle" of the shackle. Gonna have to do some tweaking. Link to comment Share on other sites More sharing options...
FxRacing282 Posted September 13, 2007 Share Posted September 13, 2007 i suggest a 2lb hammer for that tweaking Link to comment Share on other sites More sharing options...
pingpong Posted September 13, 2007 Share Posted September 13, 2007 Cw... Have you had a problem with crushing the exhaust tip... I almost think you would at full stuff Link to comment Share on other sites More sharing options...
CWLONGSHOT Posted September 13, 2007 Share Posted September 13, 2007 Nope, not at all. I kinda was worried as well...but I have had it very twisted and nothing even touched!! The pics are deceiving. It would have to invert the leaf to get contact, let alone damage the pipe. CW Link to comment Share on other sites More sharing options...
