All around mj Posted February 28, 2019 Posted February 28, 2019 1990 Jeep Comanche Pioneer 4x4 4.0L I6 / AW4 trans / NP231 tc / Dana 30 front / Dana 35 rear / SWB Build Date: 9-89 Current Location: S/W Missouri Status: daily driver/on going project Current Owner: My Good Self Notes: Engine, transmission, and transfer case, along with the cat forward are from the 1993 Cherokee Country donor. Everything under the dash forward is also from the cherokee; computer, wiring harness, radio, a/c heater control, gauge cluster, under dash courtesy lights, and cooling system. The fenders and hood, along with the front of the inner fenders were also transplants from said cherokee. I bought and installed a Spectre cowl fed cold air intake before my high output swap ( wish I could get my hands on their high output version but they no longer make either one). I still have a lot of future plans. I guess I’ll have to start a thread for that. I do currently run 12 hole injectors with harness adapters but will upgrade pigtails when I get to building and swapping my stroker.
JMO413 Posted May 25, 2019 Posted May 25, 2019 *X1 TRIM STYLE X1 - CLOTH BENCH -H9 174 Zone 74-Denver 1AA U.S. Dealer Retail 5KM AMES Department Stores AHL Heavy Duty Insulation Group ALM Longhorn Southfork Package APA Monotone Paint ARL 300 Premium Group BAY 105 Amp Alternator BCY 475 AMP BATTERY BGA Power Front Disc/Rear Drum Brakes CBA Straight Back Bench Seat CKA Carpets - Floor and Cargo Area CSR Passenger Assist Handles DGB All 4-Speed Automatic Transmissions DGS 4-Speed Automatic AW4 Transmission DHN Command-Trac Part Time 4WD System DHT Elec,Shift-on-the-Fly,P/Time T/Case DJH 230MM Front Axle DMD 3.55 Rear Axle Ratio DRJ 175MM Rear Axle EAA All Engines EAF ALL FUEL INJECTED ENGINES-GAS ERB ENGINE - 4.0L I6 MPI GAS GAC Tinted Glass Windows GBB Tinted Windshield Glass GCB Front Door Tinted Glass GEH Fixed Door Vent Glass GFD Rear Sliding Window GNA Rear View Day/Night Mirror GRZ Left Remote Mirror GSZ Right Remote Control Mirror GTZ Manual Remote Mirrors HAA Air Conditioning HGD Deluxe Insulation Group JAZ DO NOT USE - See JP, KA classes JCA 85 MPH Primary Speedometer JHA Var Intermittent Windshield Wipers JJA Cigar Lighter K2X STRIPE/BADGE/MOLDING/COLOR K3W STRIPE/BADGE/MOLDING/COLOR KKG LBC Glove Box Lamp LCJ DOME/READING LAMP B-PILLAR LMA Halogen Headlamps MB1 Black Front Bumper MBJ Black Powder Coated Front Bumper MDA Front License Plate Bracket MFG Body Color Headlamp Bezels MHA Black Windshield Moldings MMC Rear Door Solid Window Insert MMG Belt Moldings MMK Lower Grille Surround-Painted Silver NAF High Altitude Emissions NBK EVAP Control System NF2 18.5 Gallon Fuel Tank NHM Speed Control PW7 Bright White Clear Coat QW7 Bright White Clear Coat RAA All Radio Equipped Vehicles RAB AM/FM Radio RCD 4 Speakers SBA Power Rack and Pinion Steering SCE Alcantara Wrap Steering Wheel SFA Standard Duty Shock Absorbers SGA Rear Shock Absorbers SUA Tilt Steering Column TAA All Tires TBB Full Size Spare Tire TBM Tire Carrier Winch TMW P265/60r18 BSW A/S All Terrain Tires WJM 15X7.0 Chrome Wheels WLZ All Aluminum Wheels XBS Pickup Box YAA Build To U.S. Mkt. Specifications YEP Manuf Statement of Origin YGE 5 Additional Gallons of Gas Z01 Rear Spring Group I Z5A GVW/Payload Rating Z66 Left Front Group XV Z85 Right Front Spring Group XIV Body Model JL61 Build Date 9/14/89
jdog Posted February 6, 2021 Posted February 6, 2021 Correct VIN: 1J7FJ36L5LL139423 @fiatslug87 @Pete M can you fix the title Selling Dealer: THE WESTERN MOTOR CO INC Garden City, KS
