beaterjeep Posted August 28, 2007 Posted August 28, 2007 Okay, as most everyone on here knows, I'd like to lower my 88. My question is, if I were to remove one of the leafs from each side, would I be able to use them leafs in my 86's pack to produce a mini lift? If so, which leaf should I remove from the 88, and where should I put it into the 86's packs? Or am I just off in fantasy land again?
beaterjeep Posted August 29, 2007 Author Posted August 29, 2007 I'll take it that I asked a wrong question?
rockhardzj Posted August 29, 2007 Posted August 29, 2007 I'll take it that I asked a wrong question?No, I would ask the same question, but I don't lower vehicles... I just lift em...
Pete M Posted August 29, 2007 Posted August 29, 2007 It's never a good idea to remove leafs from an MJ. The spring-wrap would become unbearable. It's better to use a lowering block.
beaterjeep Posted August 29, 2007 Author Posted August 29, 2007 Thanks Pete, that's the kind of answer I was looking for. Very precise and to the point. Okay, so no removing leafs on it. SouthLake, well, I'm laughing too hard to even think of something to say.
Tracker Posted August 30, 2007 Posted August 30, 2007 What's "lowering"? It's a symptom of a car owner's disease that first appeared in this country in the 1950's. It mainly affected those people who owned vehicles that were not capable of anything otherwise remarkable. For the most part, the disease is on the decline but still somewhat prevalent in high density urban envrionments. Expert agree that it can be contracted through close association with a contagious person or in some cases, completely hereditary. It may run its course and disappear in a generation or two because close prolonged exposure to high powered sounds below 700 cycles causes sterility. :rotfl2:
beaterjeep Posted August 30, 2007 Author Posted August 30, 2007 What's "lowering"? It's a symptom of a car owner's disease that first appeared in this country in the 1950's. It mainly affected those people not capable of anything otherwise remarkable. For the most part, the disease is prevalent in high density urban envrionments. Expert agree that it can be contracted through close association with a contagious person or in some cases, completely hereditary. It may run its course because close prolonged exposure to high powered sounds below 700 cycles causes sterility. :rotfl2: There, I fixed it for ya. Oh, and about the sounds below 700 cycles; is that true? EDIT: I'm still laughing too hard to type correctly. Thanks, after the past couple days I've had, I needed that laugh.
rockhardzj Posted August 30, 2007 Posted August 30, 2007 What's "lowering"? It's a symptom of a car owner's disease that first appeared in this country in the 1950's. It mainly affected those people who owned vehicles that were not capable of anything otherwise remarkable. For the most part, the disease is on the decline but still somewhat prevalent in high density urban envrionments. Expert agree that it can be contracted through close association with a contagious person or in some cases, completely hereditary. It may run its course and disappear in a generation or two because close prolonged exposure to high powered sounds below 700 cycles causes sterility. :rotfl2: Don't forget, the "lowering" fad had a large gathering in the mid to late 80's with such deceased magazines as Lowrider. There was also a fact I read somewhere that mentioned people who lower their care also lower the chances of reproduction by 87% for having a female, and 96% for having a male. The fact also went on to mention that artificial insemination only has a 3-5% increase in chances over the losses of helping with reproduction. There is a cure though, although it was very vague about bringing the "fixing" the vehicle in question. :D
Oizarod115 Posted August 30, 2007 Posted August 30, 2007 :yes: haha. i wonder if you wouldnt be better off finding some other leaf springs from another vehicle, i know the grand waggy had leafs similar in size and i bet they have a higher spring rate which would go along nicely with handling for a lowered truck :dunno:
FxRacing282 Posted August 30, 2007 Posted August 30, 2007 aint nothing wrong with a lowered c-10 with a 350 2wd short bed
