1998 Comanche Posted December 2, 2018 Share Posted December 2, 2018 (edited) I was asked to start a build thread on a 1988 comanche /98 cherokee update. So here goes. I don't find that the swap is very difficult as both trucks are based off the same unibody but with 10 years difference there are subtle changes. The old mj was renix era and used a GM steering column shift included. The xj uses obd2 and floor shift. The hole through the firewall for column will have to be relocated close to brake booster. Measure and holesaw this. Not real big deal. The hvac box is pretty direct. Redrill the lower bolt by fan motor and slightly elongate 2 directly behind motor. The old mj steering column mount just dropped down from firewall. Drill out all spotwelds and toss it. The newer xj mount is a big aluminum piece that also bolts to left kick panel. These will need to be redrilled and the old mj ebrake bracket and studs should be removed also. The mj door strikers will need to be replaced with xj parts. Again some redrilling with careful measurements should do it. I’ve tried to upload pics but it’s super slow. Follow me on IG @88_comanche_chief. They are all there Edited December 22, 2018 by 1998 Comanche Pics Link to comment Share on other sites More sharing options...
Pete M Posted December 8, 2018 Share Posted December 8, 2018 keep tryin' with the pics. you'll get it. Link to comment Share on other sites More sharing options...
1998 Comanche Posted December 10, 2018 Author Share Posted December 10, 2018 On 12/2/2018 at 2:39 PM, 1998 Comanche said: I was asked to start a build thread on a 1988 comanche /98 cherokee update. So here goes. I don't find that the swap is very difficult as both trucks are based off the same unibody but with 10 years difference there are subtle changes. The old mj was renix era and used a GM steering column shift included. The xj uses obd2 and floor shift. The hole through the firewall for column will have to be relocated close to brake booster. Measure and holesaw this. Not real big deal. The hvac box is pretty direct. Redrill the lower bolt by fan motor and slightly elongate 2 directly behind motor. The old mj steering column mount just dropped down from firewall. Drill out all spotwelds and toss it. The newer xj mount is a big aluminum piece that also bolts to left kick panel. These will need to be redrilled and the old mj ebrake bracket and studs should be removed also. The mj door strikers will need to be replaced with xj parts. Again some redrilling with careful measurements should do it. I’ve tried to upload pics but it’s super slow. Follow me on IG @88_comanche_chief. They are all there Link to comment Share on other sites More sharing options...
1998 Comanche Posted December 10, 2018 Author Share Posted December 10, 2018 Steering shaft firewall modifications. New heater core and AC evap for HVAC box before install. My handy motor plate I made to pull engines. Bolts in place of ac compressor. Link to comment Share on other sites More sharing options...
1998 Comanche Posted January 26, 2019 Author Share Posted January 26, 2019 Link to comment Share on other sites More sharing options...
Pete M Posted January 26, 2019 Share Posted January 26, 2019 I've said it before, I'll say it again... I love the 97+ washer bottle mod. It's just brilliant! Link to comment Share on other sites More sharing options...
1998 Comanche Posted January 29, 2019 Author Share Posted January 29, 2019 Yes it’s cool. I guess the 2 pumps are for front and rear on xj. I’m goin to plumb them together on comanche. Link to comment Share on other sites More sharing options...
Pete M Posted January 29, 2019 Share Posted January 29, 2019 interesting. that might cause the spray to overshoot the glass, but there's no way to know without trying. keep us posted! Link to comment Share on other sites More sharing options...
Dzimm Posted January 29, 2019 Share Posted January 29, 2019 20 minutes ago, 1998 Comanche said: Yes it’s cool. I guess the 2 pumps are for front and rear on xj. I’m goin to plumb them together on comanche. 13 minutes ago, Pete M said: interesting. that might cause the spray to overshoot the glass, but there's no way to know without trying. keep us posted! I'm guessing the same as Pete, too much pressure potentially. Could also back feed one of the pumps if you don't put a check valve in. Could plum the rear one out to the rear bumper and give the tailgaters a nice surprise. Link to comment Share on other sites More sharing options...
1998 Comanche Posted January 31, 2019 Author Share Posted January 31, 2019 I ll try both and if too much I ll just disconnect one! Link to comment Share on other sites More sharing options...
1998 Comanche Posted January 31, 2019 Author Share Posted January 31, 2019 Link to comment Share on other sites More sharing options...
1998 Comanche Posted February 2, 2019 Author Share Posted February 2, 2019 Link to comment Share on other sites More sharing options...
Flexj Posted February 3, 2019 Share Posted February 3, 2019 Definitely loving the washer bottle. I may have to steal that idea. 😂 Link to comment Share on other sites More sharing options...
1998 Comanche Posted March 7, 2019 Author Share Posted March 7, 2019 Drivetrain installed. Tj fuel tank mounted. Link to comment Share on other sites More sharing options...
1998 Comanche Posted March 14, 2019 Author Share Posted March 14, 2019 Wiring install Link to comment Share on other sites More sharing options...
