murdamanche Posted November 30, 2018 Posted November 30, 2018 hey guys, so i decided to do a SOA conversion for the rear lift and i did some searching but I'm not 100% on what is needed. i got new 3 hole weld in perches new leafs so i will need new U-bolts http://www.rustysoffroad.com/rustys-dana-35-dana-44-u-bolts-hd-grade-8-each.html new strut mounts http://www.rustysoffroad.com/rusty-s-u-bolt-plates-mj-comanche.html am i missing anything or a picture of your set-up would be great Thanks Dave
Eagle Posted November 30, 2018 Posted November 30, 2018 The Dana 35 uses smaller diameter axle tubes than the Dana 44. If those U-bolts from Rusty's claim to fit both -- they must be sized for the Dana 44, which means they aren't right for the Dana 35. Which axle do you have?
MeanLemons Posted December 1, 2018 Posted December 1, 2018 6 hours ago, Eagle said: The Dana 35 uses smaller diameter axle tubes than the Dana 44. If those U-bolts from Rusty's claim to fit both -- they must be sized for the Dana 44, which means they aren't right for the Dana 35. Which axle do you have? D35 & d44 both have 2.76 axle tubes. He has a d44 (lucky him)
dasbulliwagen Posted December 1, 2018 Posted December 1, 2018 My Dana 35 has 2.5" axle tubes. And I was under the impression that the 44 is 3".
dasbulliwagen Posted December 1, 2018 Posted December 1, 2018 I did spring over recently. I bought the 2.5" u bolts and some weld on shock brackets as well as the 3 hole spring perches that were made for the Dana 35. The shock mounts I bought didn't end up working for me due to the length of the shocks I had to put on it. They are Bilsteins but were made for a Ram 1500 2 or 3" lift kit. Proper length shocks might give a different result. I ended up putting the original shock mounts back in their original positions under the axle, installing new regular spring plates on top and used straight grade 8 bolts to connect them. It turned out to be the perfect setup for the shocks as the axle at full droop and the shocks at full extention ended up within a quarter inch of each other.
mnkyboy Posted December 1, 2018 Posted December 1, 2018 It's something like 2.62" vs 2.76" . Some TJ D44s are supposedly the same as the D35 but MJ/XJ D44s are definitely a larger diameter.
MeanLemons Posted December 1, 2018 Posted December 1, 2018 My d35 that I took out of the 88 mj was 2.75. Other d35s I ever came across was 2.75
murdamanche Posted December 3, 2018 Author Posted December 3, 2018 On 11/30/2018 at 11:03 PM, dasbulliwagen said: I did spring over recently. I bought the 2.5" u bolts and some weld on shock brackets as well as the 3 hole spring perches that were made for the Dana 35. The shock mounts I bought didn't end up working for me due to the length of the shocks I had to put on it. They are Bilsteins but were made for a Ram 1500 2 or 3" lift kit. Proper length shocks might give a different result. I ended up putting the original shock mounts back in their original positions under the axle, installing new regular spring plates on top and used straight grade 8 bolts to connect them. It turned out to be the perfect setup for the shocks as the axle at full droop and the shocks at full extention ended up within a quarter inch of each other. Ya i have D44, how did you get the right angle on the Drive shaft to weld them on? i was going to assemble the leafs with the drop brackets and put the perch under the spring, lower the jeep down and use a small jack to adjust the shaft angle and tack weld them in then ill use my stick welder with 7018? what do y'all thing?
murdamanche Posted December 3, 2018 Author Posted December 3, 2018 On 11/30/2018 at 10:06 PM, MeanLemons said: D35 & d44 both have 2.76 axle tubes. He has a d44 (lucky him) lucky indeed! now take your bed off for me lol
MeanLemons Posted December 3, 2018 Posted December 3, 2018 1 hour ago, murdamanche said: lucky indeed! now take your bed off for me lol Hold your horses. Be a gentleman and woo me first.
dasbulliwagen Posted December 3, 2018 Posted December 3, 2018 4 hours ago, murdamanche said: Ya i have D44, how did you get the right angle on the Drive shaft to weld them on? i was going to assemble the leafs with the drop brackets and put the perch under the spring, lower the jeep down and use a small jack to adjust the shaft angle and tack weld them in then ill use my stick welder with 7018? what do y'all thing? I did a similar thing. Assembled it with the springs and U bolts, but not tight, and set it down under its own weight. Took my angle measurement off the t case output and then set the pinion angle and tacked it. Then removed one U bolt at a time and burned it in.
