Hey guys, 86 2.5L Renix 5spd. The truck has a rough idle, putters when accelerating but occasionally jumps back into normal operation and then putters again. At higher rpms it seems to be ok, but definitely feels sluggish. I changed the fuel filter just as a starting point but little to no difference. I just bought it in July and the guy said he had just changed plugs, wires, and distributor(and had a 14 year long log of all work done to it with receipts, so I trust it). Any suggestions on where to start looking first?
 in the link in my signature you'll find Cruiser's tips for renix Jeeps.  I would run through those first.  :L:
I’ve been planning on rolling through those when I have time, even have it bookmarked, but was hoping maybe there was something I wasn’t thinking of or heard of yet that might contribute to this issue.
Check the spray pattern of the injector using a flashlight. Spray pattern should be cone shaped and fine mist (no fuel droplets). See if pattern changes when vehicle runs poorly.
Don't wait on doing the Tips. Do them first.
The firewall ground is huge on the 4 cylinders for some reason.
also, inspect the hoses below the throttle body and make sure your intake manifold bolts haven't loosened up.
