mancheflo Posted October 10, 2018 Posted October 10, 2018 Has anyone ever put these kind of Mirrors on instead of the little black ones
Eagle Posted October 10, 2018 Posted October 10, 2018 Those are intended for larger trucks. To mount those with the mirror head at the right height, you'd be mounting almost to the bottom of the door. They're 27-1/2 inches high -- that's 2 feet 3-1/2 inches. Take a tape measure out to your truck and lay that out on the door. There's a more compact version that would be more suitable for an MJ, if you like that style of mirror. https://www.amazon.com/CIPA-45500-Style-Lowmount-Full-Chrome/dp/B00029WSYK?keywords=truck+mirrors&qid=1539134678&s=Automotive&sr=1-8&ref=sr_1_8 This is closer to what the factory tow mirror option was: https://www.amazon.com/CIPA-41000-Universal-Chrome-Replacment/dp/B00029WSXG?keywords=truck+mirrors&pd_rd_i=B00029WSXG&pd_rd_r=c9602175-79da-4ded-b253-7de7b34a32c4&pd_rd_w=Q0fdy&pd_rd_wg=0sTkO&pf_rd_i=truck%2Bmirrors&pf_rd_m=ATVPDKIKX0DER&pf_rd_p=be4e4b33-ff1d-476e-a827-fb55b7c4763f&pf_rd_r=0F1P3TDZ795RJEDF25DB&pf_rd_s=loom-desktop-bottom-slot&pf_rd_t=301&qid=1539134757&s=Automotive&ref=sxbs_sxwds-stvpv2
mancheflo Posted October 10, 2018 Author Posted October 10, 2018 3 minutes ago, Eagle said: Those are intended for larger trucks. To mount those with the mirror head at the right height, you'd be mounting almost to the bottom of the door. Is there any out there that kind of style would work? Like some from an early 90s f150
Eagle Posted October 10, 2018 Posted October 10, 2018 I edited my post while you were typing. See above.
mancheflo Posted October 10, 2018 Author Posted October 10, 2018 1 minute ago, Eagle said: I edited my post while you were typing. See above. Exactly what I was looking for thanks!
Eagle Posted October 10, 2018 Posted October 10, 2018 Be advised that MJs and XJs with the factory tow mirrors had a reinforcing plate inside the door to beef up the skin. If you're going to install any mirror of this general type, it would probably be a good idea to back up the upper and lower mounting points with some heavy-gauge sheet metal.
mancheflo Posted October 10, 2018 Author Posted October 10, 2018 5 hours ago, Eagle said: Be advised that MJs and XJs with the factory tow mirrors had a reinforcing plate inside the door to beef up the skin. If you're going to install any mirror of this general type, it would probably be a good idea to back up the upper and lower mounting points with some heavy-gauge sheet metal. And if were to get them what would I put in place where that corner is where the mirror currently mounts
Eagle Posted October 10, 2018 Posted October 10, 2018 2 hours ago, mancheflo said: And if were to get them what would I put in place where that corner is where the mirror currently mounts Heh, heh ... I was going to ask you that.
JeepSchmidt O'Guinness Posted October 10, 2018 Posted October 10, 2018 I think yellaheep had some mirror delete panels posted in his Colorado stuff at the for sale board... That is if eagle hadn't already pm'd you ;¶
87MJTIM Posted October 10, 2018 Posted October 10, 2018 16 hours ago, HOrnbrod said: These were optional on MJs and XJs. Nice truck, Horn. But it looks like a Renix
HOrnbrod Posted October 10, 2018 Posted October 10, 2018 6 minutes ago, 87MJTIM said: Nice truck, Horn. But it looks like a Renix Sure is a nice truck Tim. That's why I used your pic.
87MJTIM Posted October 10, 2018 Posted October 10, 2018 3 minutes ago, HOrnbrod said: Sure is a nice truck Tim. That's why I used your pic. Not a problem.
Eagle Posted October 10, 2018 Posted October 10, 2018 The early base (SporTruck) models didn't have the dual mirrors mounted at the vent window corners, and the trucks with tow mirros (such as Tim's truck in the photo Hornbrod posted) also didn't have them. This was also true for XJs with the tow mirror option. So check junkyards. This might be a good project for someone with a 3-D printer. It's a small, fairly simple part. Who here has a 3-D printer and scanner setup, or access to them?
WahooSteeler Posted October 10, 2018 Posted October 10, 2018 In addition to checking with Yellaheep, check with SaveevryJp on here, he has ton's of parts and may have the mirror delete piece.
