Cali Cruse Posted September 27, 2018 Share Posted September 27, 2018 So I'm aware that when turn signal is flashing fast, it's a weak relay. Problem is, I looked at the manual and cannot find a dedicated relay for the turn signal switch. Can't be a fuse issue, as it's not a role of a fuse to provide intermittent power. Link to comment Share on other sites More sharing options...
88mancheman Posted September 27, 2018 Share Posted September 27, 2018 I'm no expert if I where you I'd wait for Eagle or someone to chime in but in my experience there is a 20 amp fuse for the turn signal, backup lights, & rear window defogger it should be fuse #4 in the fuse box behind the break/clutch pedal, there is also a relay for the turn signals located to the lower left of the fuse panel its a large round looking thing check both of those just encase something shorted or is just going bad, also check the bulbs and make sure they are in good condition that's just my quick 2cents hopefully I helped a little Link to comment Share on other sites More sharing options...
88mancheman Posted September 27, 2018 Share Posted September 27, 2018 1 25 Amp Rear washer / wiper - Located just right of top center in fuse bank. 2 15 Amp Radio, Cigarette lighter 3 25 Amp Heater blower motor - (* - if this keeps blowing or you only have heat on one speed check your blower motor resistor pack.) 4 20 Amp Turn signal, Back-up lights, Rear window defogger relay 5 10 Amp Dome light, Courtesy lights, Glove box light, Cargo light, Radio memory, Power mirrors, Teltak connector (For old analog "bag" cell phones, I think.) 6 15 Amp Hazard warning lights, Brake / Stop lights 7 10 Amp Parking lights, Headlight Warning Chime/Buzzer, Instrument panel light dimmer 8 7.5 Amp Gauges, Instrument cluster, Seat belt warning, Headlight delay, Chime module, Overhead console 9 5 Amp Instrument panel illumination 10 25 Amp Rear window defogger 11 30 AmpCircuit Breaker Power door locks, Power seats, Trailer towing wiring harness 12 10 Amp ETR (Delco OEM) radio, Power antenna 13(1984 - 1987) - - - Spare Fuse (GM automatics and manual transmissions.) 13(1988) 7.5 Amp Transmission control unit (For AW4 automatic transmissions) 14 25 Amp Headlight delay, Horns, Security alarm 15 5.5 AmpCircuit Breaker Front windshield wipers 16 30 AmpCircuit Breaker Power Windows 17 10 Amp Clock, Security alarm (Ignition) Link to comment Share on other sites More sharing options...
SVPete Posted September 27, 2018 Share Posted September 27, 2018 The flasher relay is the top circle in the above diagram (since the lower right is marked HAZ). That doesn't mean the orientation of your fuse box matches the diagram. Look at the fuse box located down by your left foot. Swap the large circular relays, you'll know which ones by looking. If someone has put LED's in all signal locations that can cause a hyperflash unless you install a relay that supports LED's. Link to comment Share on other sites More sharing options...
Cali Cruse Posted September 27, 2018 Author Share Posted September 27, 2018 Perfect. Thanks. Ill swing by AutoZone on the way back. Link to comment Share on other sites More sharing options...
Cali Cruse Posted September 27, 2018 Author Share Posted September 27, 2018 Oh and it probably needs to be a 3 terminal one rather than 2? Link to comment Share on other sites More sharing options...
ParadiseMJ Posted September 27, 2018 Share Posted September 27, 2018 The two flashers are the same. Take one with you to the parts store. On my truck the fast blink used to mean a bulb was out, when the flasher went out it didn't blink at all, just steady on. Link to comment Share on other sites More sharing options...
Eagle Posted September 27, 2018 Share Posted September 27, 2018 2 hours ago, Cali Cruse said: Oh and it probably needs to be a 3 terminal one rather than 2? Actually, my recollection is that it's two, but pull one of your old ones to verify. Link to comment Share on other sites More sharing options...
Cali Cruse Posted September 28, 2018 Author Share Posted September 28, 2018 Problem solved. Two terminal $12.99 part at AutoZone. Heavy duty. Thanks all. Link to comment Share on other sites More sharing options...
cruiser54 Posted September 28, 2018 Share Posted September 28, 2018 for future reference, turn the signals on. Touch each flasher with your finger. The one you can feel clicking fast is the culprit. Link to comment Share on other sites More sharing options...
