mark 39 Posted September 12, 2018 Posted September 12, 2018 Finally tried the REM that I got last December. How does all that info fit in such a small box? A few questions mainly for my edification. 1) ST Fuel trim default is 128. Should real time running number be higher or lower if everything is working properly ? 2) Is the voltage reading on REM for O2 sensor (12v-5v) from before the final connection to the sensor ? ( Back probe sensor side if in doubt ?) 3) Where did those of you with a REM route the cord through the firewall , dash, etc. Thanks for answers and any hints for using this toy to advantage. Mark
87MJTIM Posted September 12, 2018 Posted September 12, 2018 1. The default fuel trims are 128. ST adjusts faster. LT adjusts based on the ST trend. Fuel trims <128 = rich condition; >128 = lean condition 2. The O2 heater relay operates on 12v. The o2 sensor operates on 0v - 5v. It should keep jumping from low to high. 3. I routed the wire along the firewall, over the booster, then through a hole in the top of the firewall next to the fuse box. I then routed under the dash into the back of the ash tray, where i have the REM sitting.
fiatslug87 Posted September 13, 2018 Posted September 13, 2018 Routed mine along the firewall then through the bung just above the speedometer cable, the orange wire in the first picture. Then modified a switch panel dummy plug to fit a cat5 keystone connector. I need to move it between three MJs so I have the same set up in each.
Strokermjcomanche Posted September 13, 2018 Posted September 13, 2018 Answer 3 , in my center console .
